is it crack???
mastaYD
by mastaYD
no creaking sounds. I shaved that rough coats but nothing crack lines on it.
do you think it is crack from inside?? or just clear coat off?
handlebar is neilpryde carbon handlebar. which made by ritchey
http://imgur.com/wVHmRyO
http://imgur.com/crMck59
Stolichnaya
by Stolichnaya
That does not look smokeable so I would venture to say it is not crack. :D
This looks like the clear coat was pinched in the stem from over torquing the bolts. I had this happen on a Easton carbon bar and it was no real issue. I would use carbon paste and a torque wrench to reinstall those bars. If you have a real concern for you, take it to the dealer and ask for their official opinion. Photos from a different angle with macro setting and better lighting might also assist to see the situation.
