Cannondale hollowgram SiSL2 - removing FSA rings/spider
by Brianblunt
Hello all,
So i have a 2013 C'Dale supersix evo red racing model, the bike came with the cannondale SiSL2 hollowgram crank set, however, it didn't come with the spidering chain rings. Instead, it came with the FSA gossamer rings, so my question is, can i replace the fsa gossamer chain rings with the spiderring chain rings? Picture attached for reference. Image
Thanks in advance!
Made your title more descriptive, to help others in the future find it should they have the same question.
by TheDoc
Yes. You'll need the KT013 crank extractor to remove the crank arm and then the KT012 spider locking removal tool to remove the existing chainring/spider combo. Should be a pretty straight forward swap. The manuals are on the Cannondale website too.
by Spinnekop
Yes. Very easy to do as per post above.
Here is just one of the shops I have seen that sells the spider as a separate unit: ... _1749.html
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
by Brianblunt
thanks for the feedback guys, going to work on that now, will post pics when done :thumbup:
