Force 22 chainrings on P2M Rotor 3d?
Fhendry1
by Fhendry1
Does anyone know if it is possible to use the chainrings from my current force 22 chainset on a P2M rotor 3d chainset? The chainrings are hidden bolt so that might be an issue.
If I can't use them what would people suggestions be for chainrings to use? The praxis works work you can get from P2M? Is there a difference between 10 and 11 speed chainrings?
Sorry about all the question, I would be very grateful for any help.
jever98
by jever98
Hi,
Nicolas from power2max here. You can install the Force22 chain rings, but the chain drop pin will be on the wrong side. I know that some people ride that way.
In terms of 10 and 11 speed chain rings. THere can be differences. The Praxis Works are approved for both 10 and 11 speed and we get consistently positive feedback on them.
Cheers
Nicolas
No longer in the industry
DiscoBoy
by DiscoBoy
If you have the budget, get praxis works rings, they are very stiff.
