It is currently Thu Dec 14, 2017 6:37 pm
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Aug 11, 2014 4:55 am
Getting back on the road with tubulars for me was actually easier than trying to patch an inner tube. Removed valve core, poured some Stan's sealant, gave it a couple whirls, and pumped back up and was riding again. Didn't need to wrestle off the clincher tire, tire levers or trying to remount tires. After two punctures, I think I can get back on the road within 10 minutes now.
PostPosted: Mon Aug 11, 2014 1:09 pm
1415chris wrote:
For the records London-Surrey with the stress on Surrey as the most part of the race was ridden in Surrey ;)
Fair point ;)
PostPosted: Mon Aug 11, 2014 9:25 pm
dha wrote:
Fair point ;)
I pu55ied out and put on my alu clinchers. No punctures though, and just under 41km/h avg
In a ride with that number of competitors and the conditions it would be really interesting if they collected detailed data on what tyres people were riding, how many punctures etc.
PostPosted: Tue Aug 12, 2014 12:10 pm
I only have zipps at the moment so had to go with them. It was interesting at times. If I had alu wheels I would have ran with them, no question.
PostPosted: Tue Aug 12, 2014 7:32 pm
If Vittoria CX was cheaper, would you get this? What is difference?
PostPosted: Wed Aug 13, 2014 11:05 am
For an example of how the carbon (and I would assume Arenberg) resist punctures here is what I have just removed from them after this weekends Ride London-Surrey. Which for those who don't know was particularly wet (up to the BB in places).
Two pieces of flint and three pieces of glass removed.
PostPosted: Wed Aug 13, 2014 12:13 pm
This is the secret to using tubs. Checking the tires and removing the diamonds from the tire. Once a week. If they are left in place they will cause punchers
I use both tires on different wheels. I hope the arenburgs last a little longer but it really doesn't matter if what tire u use as long as it's a veloflex and you don't bang 120psi in it, it's a sweet ride :D
Skunkworks Bikes
PostPosted: Sat Mar 28, 2015 6:16 pm
A few have mentioned on this thread that the Arenbergs are "plump" with actual measurements closer to 26mm. Does anyone have some actual measurements of the Carbons? Do these also measure slightly larger than their listed 23mm?
It's all downhill from here, except for the uphills.
PostPosted: Sat Mar 28, 2015 7:03 pm
@Fogman - I just measured the Arenbergs on my Campagnolo Bora One (24.5mm-wide rim) and they are bang on 25mm.
PostPosted: Sat Mar 28, 2015 8:18 pm
the carbon changed, the 22mm officially gaining 1mm to become 23mm, i recall checking when i first got one of the new ones, it measured close to 23mm (on lw obermayer wheel)
on the same wheels arenbergs measure 26mm (checked at 6 bar and 8 bar), maybe the narrower lw rim bed distorts it a bit?
PostPosted: Thu Aug 18, 2016 11:42 am
Instead of going for the continental attack/ force comp combo on my Zipps 303, I'm now looking to buy Veloflex tubs (as advised here).
Was considering giving the 25mm of the Arenberg a try, does anyone have them on a Dogma F8?
Is the F8 tire clearance Ok for the arenbergs?
thanks
PostPosted: Thu Aug 18, 2016 1:21 pm
I have 25mm Vittoria CX Isogrip tubulars on my Dogma F8. No clearance issues whatsoever. I plan on using Veloflex Arenberg tubulars when these wear out.
PostPosted: Thu Aug 18, 2016 1:51 pm
Thanks for the info fogman!
PostPosted: Thu Aug 18, 2016 1:56 pm
thanks
Yes no problem.
PostPosted: Fri Aug 26, 2016 10:53 pm
And I ended up going for carbons, but now that I got them I'm beginning to regret the decision as they look rather thin...
Anyway, do they stretch nice? They look so small, almost like a 26' bike!
I've only tried vittoria and Tufo tubs, and this veloflex look the smallest.
There are no new unread posts for this topic. Which veloflex tubular for HED Stingers?
SpecializedColnago
Tue Jun 13, 2017 1:54 pm
Geoff View the latest post
There are no new unread posts for this topic. Attachment(s) Veloflex / Open Tubular max internal rim width safety
possibleweenie
20
948
Tue Aug 29, 2017 11:21 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Veloflex corsa 25mm clincher tire question
poppiholla
14
1810
Wed Jan 25, 2017 7:56 am
poppiholla View the latest post
There are no new unread posts for this topic. Attachment(s) Vredestein Senso Superiore 320tpi (Update with photos compared to Veloflex)
possibleweenie
38
2538
Sat Nov 25, 2017 7:06 pm
possibleweenie View the latest post
There are no new unread posts for this topic. Leather top vs. Carbon Fiber saddles (SMP Forma vs. Carbon Lite)
dgeesaman
Thu Aug 31, 2017 11:52 am
kgt View the latest post
Users browsing this forum: Bing [Bot], morganb, rsantos450, Shrike and 42 guests
