It is currently Wed Jan 24, 2018 11:08 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Wed Jul 30, 2014 4:08 am
Hi guys,
I got 2nd hand Enve in a very good price, the previous owner gave me Enve brake pads and some other bits.
The pads are nearly done, and I was looking to replace the brake pads with one from SwissStop, if yellow or black prince.
Does any one uses the Enve 65 wheels with SwissStop pads?
I know that before Enve supplied their pads, they used to ship the wheels with the yellow king as standard pads.
The funny bit, I can get great deals on SwissStop, but Enve pads are around 40% more expensive, and in a way it seems that SwissStop makes them any way.
So what type of pads you guys using with Enve?
Thanks
Tomer
PostPosted: Wed Jul 30, 2014 5:04 am
Get the Enve pads. I've used others and the Enve are the best. This is with both Smart rims and the older Edge rims I currently have/use.
www.ergottwheels.com
PostPosted: Wed Jul 30, 2014 6:18 am
Get black as the yellow ones leave tails on the surface. But as @ergott said the Enve pads work best.
PostPosted: Wed Jul 30, 2014 4:09 pm
You should always use the ENVE pads...they are pretty good. Never, ever use the yellow swisstop...they tend to create a lot of heat. Blacks are much better but just to be on the safe side stick with the ENVE pads. BTW....warranty (for original owner) is voided is you use any other pads than the ENVE
www.royalbicycles.com
PostPosted: Wed Jul 30, 2014 4:34 pm
I just put on some of the Enve pads since the Zipp Tangente I had were worn pretty much down to nothing. I have to say, I loved the cork but the Enve are quite good. Great stopping power and nice modulation. IMHO, the yellow SwissStop are very poor, both in performance and concerning the horrible marks they left on my rims.
"Deserve's got nothing to do with it." William Munny
PostPosted: Fri Aug 01, 2014 2:18 am
Thanks guys for the info.
PostPosted: Fri Aug 01, 2014 10:15 am
use the stock enve pads. they are better then the swiss stop.
i did however use the zipp pad on my enve before as i forget to switch them out.. they work as well but the enve pad would be better
There are no new unread posts for this topic. Non-enve pads on enve wheels
AttacknowAttackoften
36
3738
Sat Jan 13, 2018 4:16 pm
izza View the latest post
There are no new unread posts for this topic. ENVE SES 4.5 with ENVE hub => brake rub
ODC
40
3593
Sat Dec 16, 2017 5:50 pm
jj911c2 View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1114
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
There are no new unread posts for this topic. CAAD 12 Disc - what brake pads?
Tue Jan 16, 2018 4:22 am
TonyM View the latest post
There are no new unread posts for this topic. Brake pads for Lightweight Meilenstein
mike001100
21
1394
Fri Nov 10, 2017 12:01 am
glepore View the latest post
Users browsing this forum: benzebub, Bing [Bot], Google Adsense [Bot], JScycle, Pijpie, torinb and 24 guests
