It is currently Sat Jan 20, 2018 10:32 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Mon Jul 28, 2014 8:28 am
Hello,
I ve got a Roval Clx60 wheels and I m not getting the braking modulation and power that i would get. I know that this whels have a carbon brake surface and never will be the same of an aluminium ones. I ve tried Corima Red and Swisstop Black Prince. Anybody has experience with this wheels (or clx40) and differents pads combinations? In this moment i m wearing swiistop on front and corima rear.
Thanks for your time and sorry my bad English!
PostPosted: Mon Jul 28, 2014 2:08 pm
Yeah I have a set of CLX40. I am currently using sram red 2011/CLX40/black prince. The braking is certainly not as good as my ee/meilensteins/black prince. I wasn't sure if my sram red 2011 brakes weren't getting the leverage due to the wide rim but apparently it isn't an issue with other wide rims. I find sanding the pads and cleaning the braking surface with alcohol helps a lot as the pads seemed to get glazed easily. Will keep an eye on this thread.
PostPosted: Mon Jul 28, 2014 2:14 pm
Have you tried the Specialized pads? I think that some of the pads mentioned above will void the warranty.
PostPosted: Mon Jul 28, 2014 2:23 pm
The stock Specialized pads are great. They wear a little quick , stopping is great. I'm using eecycleworks brakes. That might help.
PostPosted: Mon Jul 28, 2014 5:21 pm
I ve tried Corima because was sell by an specialized supplier. Here in Spain i can't find the Specialized pads. Do you know where can i find it?
PostPosted: Tue Jul 29, 2014 12:49 am
What specialized pads are you talking about. The wheels came stock with swissstop black prince pads when I got them?
Someone has recommended the Koolstop carbon black for improved power.
PostPosted: Tue Jul 29, 2014 1:44 am
I have both 60's and 40's and use the factory supplied (they are black princes) pads and Enve pads with Ciamillo and Red22 calipers. The braking isn't as good as either my Enve 6.7 clinchers or my 3.4 tubulars but the difference isn't major.
IMO, Black Prince pads are the best, readily available pads you can get for carbon wheels.
PostPosted: Tue Jul 29, 2014 9:54 am
Thanks for your coments, i will mount black prince. If anybody has more experience with other combinations (for example Reynolds crioblue) please let ne know. Now i m using sram force calipers, is there to much diference with new sram red aerolink?
PostPosted: Tue Jul 29, 2014 6:24 pm
I found the Reynolds blue pads to be a bit better, and cheaper than Black Prince pads, on FarSport rims with the basalt brake surface.
But it depends on the rims. I would not make a blanket recommendation for all carbon rims unless I had experience on a wide selection of rims.
PostPosted: Tue Jul 29, 2014 9:31 pm
Hmm, well first off, I prefaced with "In my opinion".......so.......its my opinion. Secondly, I have used ENVE, SwissStop Yellow, Black Prince and Reynolds blue on ENVE, Specialized, Reynolds, Zipp and 3 pairs of chinese hoops over the last 3 years or so.
So, I feel comfortable making that blanket recommendation. Your results may vary, my friend.
PostPosted: Tue Jul 29, 2014 10:10 pm
Campagnolo red brake pads are the best pads at the moment.
Why?
A lot of non-campagnolo sponsored teams are using them on Shimano and Sram callipers
PostPosted: Wed Jul 30, 2014 8:02 am
Are Campagnolo pads compatible with Sram callipers┬┐?
PostPosted: Wed Jul 30, 2014 11:16 am
I use also the campy pads on my dura ace 9000 brakes- best braking performance of all tested pads for the Rovals (blackprince, yellow)!
Campy produce the pads also for shimano/sram Standards - here are the products numbers: Campagnolo: BR-BO500, Shimano: BR-BO500X
PostPosted: Tue Jun 30, 2015 10:38 pm
Yes, there's is a Shimano/SRAM fit model of the campagnolo pads.
There are no new unread posts for this topic. Chorus 2015+ users
Boshk
Fri Dec 15, 2017 11:31 am
Digger90 View the latest post
There are no new unread posts for this topic. Users of the Fabric bottle cage system, opinions please.
burglarboycie
10
1364
Tue Jul 18, 2017 2:36 pm
Mrseasons View the latest post
There are no new unread posts for this topic. Carbon fiber spokes + Alloy Rim = DISASTER(for MAVIC users)
[ Go to page: 1 2 3 4 5 6 ]
ohhyeok90
80
5555
Thu Nov 16, 2017 9:57 pm
antonioiglesius View the latest post
There are no new unread posts for this topic. New Specialized Disc wheel Roval 007 disc.
Slack
Thu Dec 14, 2017 4:16 pm
TurboKoo View the latest post
There are no new unread posts for this topic. Do Roval Disc CLX 50's fit Canyon Ultimate CF SLX Disc?
dvearn
Thu Jun 01, 2017 6:32 am
hannawald View the latest post
Users browsing this forum: Google Adsense [Bot], indrek, Klaster1, pdlpsher1, raggi, ymisyd and 50 guests
cron
