Edge 510 and Stages PM (both on latest firmware)
dha
by dha
I have noticed that my Edge 510 loses the ANT+ pairing with my stages power meter since the latest software update on the Edge510. Anyone else had this?
I need to scan a few times to get it to pick it up and it occasionally drops mid ride.
kevhogaz
by kevhogaz
Mine has worked flawlessly since I installed it. Running it with a 510, as well. You might try downloading the Stages app, and making sure you're completely up to date?
dha
by dha
Yep stages is up to date. Prior to software version 3.10 on the 510 it worked flawlessly, since then less so.
FIJIGabe
by FIJIGabe
I'd say check the battery on the Stages, and reset the Garmin, just to be sure.
