It is currently Sat Apr 29, 2017 10:59 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
PostPosted: Sun Jul 27, 2014 1:28 pm
Someone just announced bearings that would allow a BB30 crank to be used in a non BB30 frame. I can't seem to find the link or remember who it was.
PostPosted: Sun Jul 27, 2014 1:35 pm
Rotor offer their solution - BSA30
PostPosted: Sun Jul 27, 2014 2:44 pm
I just installed a BB30 Quarq in a standard BSA threaded frame by using a Zipp Vuma bottom bracket. Works like a charm!
PostPosted: Sun Jul 27, 2014 3:31 pm
A number of companies make "BSA30" BBs with 30mm ID bearings in BSA cups.
But you need a crank with an extra long 30mm spindle. True BB30 crank spindles are too short.
Sram Quarq and Rotor are extra long 30mm spindle cranks.
PostPosted: Mon Jul 28, 2014 2:20 pm
Wheelsmfg. I don't think they have it up on their site yet. It was posted in another thread on here last week..look around.
Edit, think it was this thread: viewtopic.php?f=3&t=98394&start=45
PostPosted: Mon Jul 28, 2014 7:10 pm
The wheels mfg adaptors referenced in that thread are to run 24mm spindle cranks in a BB30 frame, not BB30 cranks in a BSA frame which is what this thread is about.
They look really nice though, especially the one with angular contact bearings.
PostPosted: Mon Jul 28, 2014 8:20 pm
Which bottom bracket standard as these days, 'non bb30' frames could include BSA, PF86, PF90, PF92, or BBRight, and of those, realistically only frame with a BSA bottom bracket would be able to work with a BB30 crank.
PostPosted: Mon Jul 28, 2014 8:35 pm
hmmmm,
this has got me thinking....
with those BSA30 cups I wonder if its possible to thin the bottom bracket down enough to fit the short BB30 BB30....
PostPosted: Mon Jul 28, 2014 10:19 pm
joec wrote:
hmmmm,
Why not have a go with a file and a couple of chisels?
PostPosted: Mon Jul 28, 2014 11:17 pm
this is the important detail. the "bb30" cranks that fit in BSA frames are not true bb30 cranks - they are bb30 compatible through the use of longer spindles, spacers, etc. a true bb30 crankset cannot be made to fit in a bsa frame with existing parts. to do it on a custom basis would require some pretty tiny bearings that would probably have a similarly tiny life-span.
PostPosted: Tue Jul 29, 2014 2:26 pm
Enduro is coming out with a set of 2 bearing per side to allow 30mm cranks to be used on Treks 90 mm wide shimano BB. I'm guessing very small bearings and the 2 races per side to help distribute the load. I believe it was on bike rumor a couple of weeks ago.
PostPosted: Tue Jul 29, 2014 2:35 pm
I just did a search on Google (and on BikeRumor) and haven't been able to find an article with that information. Can you provide a link?
Madone 9 http://weightweenies.starbike.com/forum/viewtopic.php?t=143973
Crockett http://weightweenies.starbike.com/forum/viewtopic.php?t=130567
Madone 5, Madone 4, SpeedConcept, Cobia
I own a lot of Treks.
PostPosted: Tue Jul 29, 2014 7:10 pm
I could have sworn that I have seen a set of Hollowgram SL cranks on a BSA bottom bracket bike with Zipp style bearings at some point. Someone I am sure did this conversion but they have to machine the lip off of the axel.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Tue Jul 29, 2014 8:34 pm
I think that was a one off, completely custom proof of concept Fairwheel bike or similar did several years back. Regardless of spindle length, isn't the bottom bracket shell for an English threaded BSA frameset ~68mm? As is always the case with a true BB30 crank, adding threaded bearing cups to that frame will result in the chainrings being pushed out the equivalent of the width of the bearing cup, thus altering the required chainline.
PostPosted: Tue Jul 29, 2014 8:49 pm
That is the one that I remember and I agree with your statement. I would like to see that article and their findings.
BIG DADDY B FLOW
There are no new unread posts for this topic. Best option for BB30 to GXP conversion (SS Evo frame)
welkman
12
1015
Wed May 18, 2016 11:53 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Think I got a frame with BBright installed, want to install Shimano crank [pic]
Shrike
20
1133
Thu Oct 06, 2016 6:18 pm
Shrike View the latest post
There are no new unread posts for this topic. Rotor Crank Compatability to Wilier Cento 1SR BB386 Evo Frame
theironboy
Sun Jan 01, 2017 2:50 pm
1415chris View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
505
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Cannondale bb30 opinions
Jcgill
Tue Apr 18, 2017 6:54 am
slick1 View the latest post
Users browsing this forum: axel, Google Adsense [Bot], hannawald, outnumbered, PSJoyce, shadowman, snowdevlin and 61 guests
