It is currently Tue Aug 22, 2017 10:21 am
PostPosted: Sat Jul 26, 2014 3:03 am
I got a deal on a Red 22 crankset (compact), cheaper than 10-speed, and someone else wrote in my Scott thread below that they were using a Red 22 crankset in a 10-speed system without any issues.
I see printed on the inner chainring "SRAM 11-speed chain / 11-speed Yaw FD only"
For sure a regular 10-speed chain will work fine, and I am almost sure my 10 speed Yaw FD will also work, but wanted to check here just in case. Anyone?
(2012/2014) Scott Addict R1, SRAM Red 6.6kg | 2012 Scott Scale Pro, SRAM X0, 9.4kg
PostPosted: Sat Jul 26, 2014 3:24 am
yeah it should work...
PostPosted: Sat Jul 26, 2014 6:53 am
I would doubt they changed chainline/chainring spacing to accomodate 11 speed.
PostPosted: Sat Jul 26, 2014 11:31 am
I use this combo....it's fine.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Sat Jul 26, 2014 6:16 pm
I'm using a Red 22 crank with 10 speed right now and it works perfectly.
I'm using a Red 10 speed Yaw FD, 10 speed chains, and Force 10 speed wyfli RD
The Red 22 crank replaced a Force 10 speed, and it actually shifts better and is quieter.
PostPosted: Sat Jul 26, 2014 7:36 pm
Thanks for the advice!
I installed the Red22 50/34 crankset and adjusted the 10-speed Yaw FD without any issues. Well, except the Scott Addict R1 FD mounting tab would not let me adjust the FD quite low enough. The gap is 3mm or so to the 50T, but it seems to work fine. There's a little chain rub on big/big, but I never use that crooked chain combination anyway, and the audible warning is nice to have should ever get in that gear inadvertently.
Just a short test ride, but I think it shifts even easier than my previous 10-speed 53/39. We shall see after a few more rides.
PostPosted: Sat Jul 26, 2014 9:23 pm
You might be able to get the FD a little lower by dremeling the slot in the mounting tab; if you feel it is necessary for smooth shifting.
When i switched to the Exogram chainrings I was astounded at how much crisper the front shfting was.
PostPosted: Sat Jul 26, 2014 9:58 pm
That's a good idea, but it works well as it is -- next time I have it off for some reason or other.
There are no new unread posts for this topic. S2-system on Campagnolo front derailleur
Daniel1975
Thu Jan 05, 2017 10:16 pm
Calnago View the latest post
There are no new unread posts for this topic. Shimano FC-R9100 crankset with 9070 Di2 front derailleur
Bigger Gear
Fri Jul 14, 2017 1:46 pm
ooo View the latest post
There are no new unread posts for this topic. Sram Etap Front Derailleur Height
goldmine848
Thu Jun 22, 2017 10:25 am
goldmine848 View the latest post
There are no new unread posts for this topic. Front derailleur limit screw rounded off (SRAM eTap), need plier recommendation
Shrike
Wed May 03, 2017 7:40 am
Shrike View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
Mon Aug 21, 2017 6:19 pm
bm0p700f View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], corky, crux, Google Adsense [Bot], Norregard, Yahoo [Bot] and 39 guests
