It is currently Tue Jan 16, 2018 1:01 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Jul 25, 2014 8:08 pm
Hi guys,
I have a wilier cento 1 st. I bought it as secondhand - 5 months old..
It has a ritchey superlogic stubby.
Some month ago, I started to get problems with mh right knee. Therefor I now need to move the saddle up a 2 cm. I already have the stubby at the end of the post. Anybody knows if its possible to get some inserts in carbon or aluminium that aloes me to move the saddle up?? Any other ideas?
Thanks a lot
PostPosted: Fri Jul 25, 2014 11:20 pm
2cm is quite a long way to extend an ISP, would your seat topper even cover that adjustment distance, it would need to be the 70mm model.
If it's a round ISP post you could try using head tube spacers, but i'm not sure of the diameters required
PostPosted: Fri Jul 25, 2014 11:37 pm
A) 2cm is a long way. How do you know it needs to go that far?
B) What do you mean by 'the end of the post'? If you mean it's at the minimum insert line already then you can't just space it further up, it wouldn't have enough clamping area so you'd need a longer topper. Ritchey should make a 70mm topper for Cento seatmasts, they do for round posts. If there are no spacers in the topper at present then you should be able to move it up. Either way it's probably best to phone a local Wilier or ritchey dealer, or your country's Wilier distributor for availability.
PostPosted: Tue Jul 29, 2014 6:29 am
Hey Zimba
Yes you can. I have a new Cento1 SR frameset still uncut and It came with extra spacers. These carbon spacers come in 10 mm, 5 mm and 2 mm. You can actually raise the seat topper by about 30 mm without violating the minimum insert line.
So if the Ritchey topper is 70 mm, and the min insert line measures 40 mm, then you have a whole 30 mm to play with. But you will need these spacers; they are the exact shape of the ISP (a truncated airfoil) and any other won't work. You may damage the ISP.
It also came with a plastic "guide" which I'm still trying to figure out what it's purpose is! If any other Weenies' out there knows, then please enlighten me.
Try asking Wilier for these, or try asking the guy you bought the frameset from if he has a 20 mm section of the ISP leftover.
By the way, what BB cups are in your BB?
Peace ~ Joe
PostPosted: Tue Jul 29, 2014 10:06 pm
{USERNAME} wrote:
I have a new Cento1 SR frameset still uncut...
Cutting, most likely :wink:
There are no new unread posts for this topic. Integrated bar and stem!
MC356
15
3694
Sat Mar 25, 2017 8:40 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Integrated cocpit for C60? Ideas?
dukezpol
14
976
Wed Dec 27, 2017 3:11 pm
c60rider View the latest post
There are no new unread posts for this topic. Workswell Integrated Handlebar
waltthizzney
Thu Nov 23, 2017 7:35 pm
glepore View the latest post
There are no new unread posts for this topic. Integrated seat mast topper
JohnnySea
Tue Jun 27, 2017 3:11 am
shimmeD View the latest post
There are no new unread posts for this topic. Why are most integrated bar/stem combos so heavy?
morganb
13
913
Tue Jan 09, 2018 5:21 pm
Chans1ee View the latest post
Users browsing this forum: asa226, Conza, Google Adsense [Bot], lovemyway, PinaF8 and 41 guests
cron
