It is currently Wed Jan 17, 2018 7:14 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Jul 25, 2014 9:30 am
Hi all,
I need some advice, I’m using Di2 internal cable routing for my bike.
While riding an uneven road and etc…. I can hear cable or cable tie noise from my bike.
Any method I can solve this noise issue..???
PostPosted: Fri Jul 25, 2014 3:09 pm
One trick is to use small zip ties around the cable so the long end/tail will stick out, put a few of those like every 4-6" or so along the cable. Then feed it into the tube. You can put a few close to one another also, like on opposite sides so the cable is either suspended/lodged between the tube walls while inside of it, or just one side and hope there is enough force to keep it against the tube so it won't make noise.
I basically did that, haven't had any noises/rattling.
There are also specific designed ones you can buy. But the small ones are good too from your local hardware store.
http://www.evanscycles.com/products/shi ... 0-ec037141
PostPosted: Fri Jul 25, 2014 3:33 pm
^ That's the best thing to do. I might also add that it's probably just the downtube wire so if you don't want to pull all the wires on the bike maybe start with that one and see if the sound disappears.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Tue Jul 29, 2014 3:18 am
Dear Zigmeister,
Thanks for the advice.
Will try it out..
PostPosted: Tue Jul 29, 2014 3:20 am
Dear rmerka
Thanks, for my advice I will try it out.....
PostPosted: Tue Jul 29, 2014 3:43 am
Could be the internal jb. Wrap it in foam.
My RCA
There are no new unread posts for this topic. Stems with internal cable routing
murphyk
Fri Oct 13, 2017 4:14 pm
kode54 View the latest post
There are no new unread posts for this topic. Top tube internal cable adapters for huge holes
LouisN
Thu Nov 16, 2017 1:43 pm
Rudi View the latest post
There are no new unread posts for this topic. Link cable housing and internal full length runs?
SpecializedColnago
Wed Apr 12, 2017 1:53 pm
reknop View the latest post
There are no new unread posts for this topic. Canyon Ultimate SLX 2015 - Internal Cable Downtube Stopper Missing
eoj
Tue May 30, 2017 3:26 am
joelpace View the latest post
There are no new unread posts for this topic. what is this Shimano cable item?
Foghat
Mon Apr 17, 2017 5:15 pm
mattr View the latest post
Users browsing this forum: Bing [Bot], bremerradkurier, CP, Delorre, gmarsden, petepeterson, sivan, SpecializedColnago, ymisyd and 33 guests
