It is currently Sun Jan 21, 2018 6:16 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Jul 25, 2014 12:57 am
Hey guys,
So I'm not at home to actually swap them out... but I visually couldn't see (that I remember) any difference between the two?
Are the pads currently cross compatible or do I need to order campy specific pads?
Cheers
PostPosted: Fri Jul 25, 2014 1:08 am
I didn't think they ever were compatible.
There's sometimes a buggy.
One.
PostPosted: Fri Jul 25, 2014 3:18 am
pretty sure the shape of the retention mechanism is different.
Even in campag world pre 2011 have a straight groove and post 2011 have a wedge shaped hole to retain the pad.
Shimano is different all together.
PostPosted: Fri Jul 25, 2014 3:37 am
I have a retaining clip on mine with there new EPS stuff, though it's never been a problem to just cut a bit more out to make it fit.
Only if the grooves for it to slide in and out are different then thats a a problem.
Anyhow just ordered more Campy Sissstop Black pro pads :)
PostPosted: Fri Jul 25, 2014 4:14 am
If you want to use Shimano style pads you could mount Shimano style pad holders.
There are no new unread posts for this topic. Sram red 22 VS Campagnolo Super Record VS Shimano 9100
Look595
Fri Mar 17, 2017 6:09 pm
AZK View the latest post
There are no new unread posts for this topic. Cane Creek EE brakes incompatible with Campy brake pads?
Noctiluxx
Sat Jan 13, 2018 3:50 am
djbowen99 View the latest post
There are no new unread posts for this topic. Chain length - Campy Record 11s on C60
3Pio
15
1322
Sat Mar 25, 2017 12:24 am
srshaw View the latest post
There are no new unread posts for this topic. Noisy Older Hollowgram crankset and 10s Campy Record Driveline
M2G
11
627
Tue Oct 10, 2017 4:52 am
M2G View the latest post
There are no new unread posts for this topic. Can a Campy Record 10-speed rear brake/shift unit be converted to
Catagory6
13
691
Wed Sep 27, 2017 1:09 am
bikerjulio View the latest post
Users browsing this forum: jimborello, moyboy, tabl10s and 36 guests
cron
