It is currently Sun Apr 30, 2017 4:07 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Thu Jul 24, 2014 2:34 am
Hi all,
Long time , first time.
2014 SS Evo Hi-Mod Frame set.
Did C-Dale use an even newer style compression plug for the steerer? On my previous bike I thought the top cap was 6mm and the bolt for the expanding wedge was 5mm.
On current bike, it seems the top cap is 5 mm and I would assume the bolt for the expanding wedge would be 4mm?
I found a similar looking expanding compression wedge on CannondaleExperts.com but the cap has an "F2" designation under the SI on the top cap. My top cap has an "L3" stamped on it. Is the torque value of 6.8nm the same as well?
Thanks for all the help.
PostPosted: Thu Jul 24, 2014 4:01 am
Torque spec remains the same; the "top cap" is revised to be much lighter (really nice machining), hence the 5/4 instead of 6/5 fitting - this is an upgrade on the nicer evo models.
PostPosted: Thu Jul 24, 2014 4:54 pm
Great. Thank you.
PostPosted: Thu Jul 24, 2014 6:19 pm
The new one is so much better. It's about 15g vs the 50g for the old one.
PostPosted: Thu Jul 24, 2014 6:29 pm
Can you take a photo of it (or find one)?
PostPosted: Thu Jul 24, 2014 6:43 pm
Old:
New:
PostPosted: Thu Jul 24, 2014 6:49 pm
Thanks. I have the old one and now I know how to shed few grams with this new one :)
PostPosted: Fri Jul 25, 2014 3:47 pm
I just built up a synapse hi-mod frameset with this same plug. When you say 6.8nm are you referring to the 4mm bolt or the 5mm? The 4mm should only be 4Nm according to the manual: http://media.cannondale.com/media/Synap ... en_low.pdf
PostPosted: Fri Jul 25, 2014 4:51 pm
If you sweat a lot, strongly recommend putting a bit of black electrical tape over the cap.
The steel expander bolt will seize to the aluminum lower body. No amount of anti-seize was enough.
Other than that, great, reliable lightweight part.
PostPosted: Fri Aug 29, 2014 4:33 am
Just a question on this as I just installed one... I was riding today and was getting awful creaks from my headset.. when I got home I was able to put the allenkey in the plug and spin it free with no effort with the stem still tight..
I reinstalled everything, and I noticed as I tighten the FSA stem bolts the cap is not holding tight.. the compression is still there though..
I do have a 5mm spacer on top, and the cap is not touching anything...
As I was tightening the stem the last time I gave the cap a half turn.. it seems to be snug in there now... but it seemed to have backed off somehow before thus my creaking issue??
PostPosted: Fri Aug 29, 2014 7:13 am
Try using some carbon paste on the plug to help add so friction. We had this issue with a few of the bikes in my shop.
PostPosted: Fri Aug 29, 2014 12:37 pm
mattyNor ahh good call.... will try that tonite!
PostPosted: Fri Aug 29, 2014 1:03 pm
Or just replace with an FSA compressor. Those cannondale plugs are terrible. There's another thread on this issue.
http://weightweenies.starbike.com/forum/viewtopic.php?t=127424
My RCA
PostPosted: Fri Aug 29, 2014 2:38 pm
I used a ultrastar 2 with my caad9 premium full carbon fork. No problems at all. Bike came with the old style plug but that thing was a tank. Running a enve 1.0 with the ultrastar without any issues. Never used carbon paste, no slippage problems.
There are no new unread posts for this topic. How to use Cane Creek 110 Top Cap with compression plug?
McGilli
Sat Jul 30, 2016 7:28 pm
headwind816 View the latest post
There are no new unread posts for this topic. Riding carbon fork without compression plug
alcatraz
24
2157
Sat Sep 10, 2016 1:44 am
alcatraz View the latest post
There are no new unread posts for this topic. Pinarello fork steerer compression plug
caballero
Thu Nov 10, 2016 3:37 pm
caballero View the latest post
There are no new unread posts for this topic. How important is Compression Plug / Top Cap Tightness after stem is tightened?
McGilli
20
1444
Fri Aug 26, 2016 1:03 am
Kayrehn View the latest post
There are no new unread posts for this topic. Zipp Vumaquad for Cannondale bb30 question
abrown3mtg
Fri Jun 17, 2016 2:28 am
Juanmoretime View the latest post
Users browsing this forum: Asteroid, Bing [Bot], Exabot [Bot], Google [Bot], krusty, RussellS, Wookski and 38 guests
