Cannondale guru needed, Compression Plug Question
by Charlie1025
Hi all,
Long time , first time.
2014 SS Evo Hi-Mod Frame set.
Did C-Dale use an even newer style compression plug for the steerer? On my previous bike I thought the top cap was 6mm and the bolt for the expanding wedge was 5mm.
On current bike, it seems the top cap is 5 mm and I would assume the bolt for the expanding wedge would be 4mm?
I found a similar looking expanding compression wedge on but the cap has an "F2" designation under the SI on the top cap. My top cap has an "L3" stamped on it. Is the torque value of 6.8nm the same as well?
Thanks for all the help.
