It is currently Fri Jan 19, 2018 8:49 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Mon Jul 21, 2014 5:28 pm
Long time reader first time caller, I was wondering if anyone has ever taken a hub and drilled it to make more spoke holes, or is that an incredibly stupid idea? I am contemplating buying a 20-hole powertap hub off a friend for super cheap but I'm not confident that a 20 wheel would hold up well for me (cat1, 173lb) on anything but a super deep rim.
PostPosted: Mon Jul 21, 2014 6:42 pm
Resident Pro
use 14 g spokes on a deep rim
PostPosted: Mon Jul 21, 2014 6:46 pm
I used a (friend's) Powertap 20 holes on a kinlin 30 mm with 14g spokes 2 X each sides. Works perfect. Very solid build.
Louis :)
It is a bad idea. The holes would not be evenly placed making spoke length calculations a nightmare and creating a funky unbalanced lacing pattern. With a normal sized hub, the extra holes you drilled would be too close to other holes so the spokes would pull through, ruining the hub. The larger diameter of the PT hub makes that less likely.
You are right about 20h not being enough for your size.
PostPosted: Mon Jul 21, 2014 11:42 pm
Take away this man's drill.
There are many issues, including precision, finishing of a spoke hole (local honing, removal of any stress risers, etc. etc.), plus why you'd want a 40-hole Powertap wheel? (I don't think Powertaps will even be accurate with extreme drillings, if I remember correctly -- they are calibrated for the spoke count the hub is drilled for.) You have a 20 spoke wheel ahead of you, or you sell the hub and get something else. And I'd agree with others above ... you need to sell the hub.
There are no new unread posts for this topic. Repurpose of downtube shifter holes
Slicknicklabel
10
1212
Thu Feb 09, 2017 1:28 am
Slicknicklabel View the latest post
There are no new unread posts for this topic. Shoes with cleat holes far forward?
C50DB
11
1217
Fri Jan 12, 2018 4:07 am
blamester View the latest post
There are no new unread posts for this topic. Attachment(s) Tips for covering holes with sugru?
hannawald
9
905
Tue Aug 08, 2017 1:23 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Drilling my Carbon Handle Bars
DeeHubbs
7
1111
Tue Aug 08, 2017 9:20 pm
JayUK View the latest post
There are no new unread posts for this topic. Top tube internal cable adapters for huge holes
LouisN
Thu Nov 16, 2017 1:43 pm
Rudi View the latest post
Users browsing this forum: Baidu [Spider], billspreston, DeRibble, dim, Frankie13, jch3n, joeg26er, L3X, lovinmylab, Miller and 48 guests
