rubber di2 grommets for in frame wiring
yumseyo
by yumseyo
Hi All, would anyone be able to tell me where I can buy some of the nice rubber grommets that are at a 30 or 45 degree angle to any tube when installed? I am installing Di2 and want to run the wires in the tubes of the frame. Thanks..
drmutley
by drmutley
They usually come with the groupset?
ALAN Carbon+
by ALAN Carbon+
You can buy the Shimano grommets from plenty of online shops or you lbs could probably order them pretty easily.
http://www.competitivecyclist.com/shima ... 2-grommets
Sent from my HTC_PN071 using Tapatalk
11.4
by 11.4
It's a little hang card with, I believe, four of them per package. There are two kinds -- ones made for round drilled holes and oval ones for oval holes (and for the shaped oval holes with a rim that many frames now use. The oval ones give slightly better cable routing but you have to match the type to the holes on your frame.
eliflap-scalpel
by eliflap-scalpel
i used Sugru instead of Shimano grommets.
waterproof result.
http://eliflap.it/
AndreLM
by AndreLM
I bought mine on fleebay. A search with the thread title should give you a couple of sellers
EvoUltimate
by EvoUltimate
eliflap-scalpel wrote:i used Sugru instead of Shimano grommets.
waterproof result.
Same here. It looks better and lighter as well. ;)
eliflap-scalpel
by eliflap-scalpel
agree
http://eliflap.it/
ms6073
by ms6073
Ah, nice. That also looks like a good option for sealing the hole for the mechanical front derailleur cable on our Scott Solace frames.
- Michael
TedStriker
by TedStriker
waterproof result.
^Was going to suggest this. Great product
Chiva
by Chiva
Silicone caulking works great too.
yumseyo
by yumseyo
I made some Shimano Di2 grommets work. Looks pretty good and so far, works well.
