Installing fsa slk chainset
tinchy
by tinchy
Hi,
I've just removed the non drive side crank arm on my fsa slk bb30 crank set. When loosening the crank arm using a 10mm Allen key, there was an initial loosening followed by a tightening and then second loosening, followed by crank arm removal. I understand this is due to the self extracting bolt mechanism.
My question is when I reinstall the crank arm using a torque wrench will the opposite occur, I.e. Tightening followed by a 'loosening' then a final tightening or will it just be a straight forward one-time tightening to the recommended torque?
Thanks
rijndael
by rijndael
It tightens normally, like any other bolt.
tinchy
by tinchy
Awesome, so just grab the torque wrench and tighten to recommended torque. I can handle that :)
