It is currently Thu Jan 18, 2018 3:17 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Stages SRAM weight..
PostPosted: Tue Jul 15, 2014 6:34 am
I rode a quick test ride with my new Stages PM and it works... That's all I can say for now about the functionality before I start learning how to use it and analyze the data better. The biggest drawback from a ww perspective is that the SRAM Rival crank arm is a beast at 210g + 20g for the Stages PM ( = 230g total). The SRAM Red arm that it had to replace is 135g. So for SRAM Red owners, the Stages weight penalty is 95g and not 20g.
(2012/2014) Scott Addict R1, SRAM Red 6.6kg | 2012 Scott Scale Pro, SRAM X0, 9.4kg
PostPosted: Tue Jul 15, 2014 11:26 am
My quarq has crapped out twice in 8 months....both times on wet rides (though the local distributor said it wasn't water ingress).
Good things:
-it's easy to replace a battery.
-Pretty light.
-Looks good (my opinion)
-good replacement (second time was over the weekend)
-data is consistent and decent once you use a qualvin app and a known mass.
Bad things:
-2 breakdowns.
-each time it's been sent back, it's been miles out from accurate and needed re-calibrating using Qualvin to get it sorted (which would be a pain if my coach didn't have that stuff and an obsessive hatred of inaccurate data, so I CAN get it fixed promptly).
I may just be the least lucky person in NZ with Quarqs but it has severely tried my patience as each breakdown has coincided with a holiday period starting (i.e. when I'm likely to do some serious K's!!)....second one was recent and really caused a temper tantrum.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Tue Jul 15, 2014 11:54 am
Another specialized SRM user here in standard BCD - lightest SRM I have used. Not a whole lot of weight penalty for the reliability and getting to use cranks I wanted.
Just ride ..
http://1k2go.bigcartel.com
https://www.instagram.com/itsacarr
https://www.strava.com/athletes/1044522
PostPosted: Tue Jul 15, 2014 4:56 pm
I think the Quarq numbers are questionable at best. They're no longer available on FSA cranks, so I suspect that weight was the previous generation unit.
The standard Quarq Riken these days is Sram crank based and weighs 739 for GXP and 733 for BB30g. The comparable Sram Red crank is 609 in GXP and 557 in BB30.
The difference is 130g GXP, 176g for BB30.
Neither of my Quarks have broken or lost accuracy yet. But it's only been four years for the older one.
PostPosted: Tue Jul 15, 2014 7:37 pm
On the subject of Stages, or the new left-only Rotor... I get L-R balances like the following very reliably with Vector:
Measuring just the left side would thus result in a significant power error in the low-power range.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Tue Jul 15, 2014 8:15 pm
Then go with Stages or the left-only Rotor. Your all-important high-end power* will increase. :beerchug:
* as indicated by the multiply left-side power by 2 algorithm, ha ha
Edit: For NiFTY's benefit, at the very highest power shown on the graph, djconnel's right leg percentage tends to be below 50, therefore, his left leg percentage tends to be above 50, so doubling left leg percentage will overstate power, hence his <indicated> power will increase by use of a left-leg only power meter. QED.
PostPosted: Fri Jul 18, 2014 4:55 am
Actually Hammertime calculated power will decrease for djconnel. I have a Quarq which estimates balance and mine is normally 48-49% L and 51-52% R. I know that my FTP set on my quarq is going to be slightly higher than that on my stages. Does 1-2% really matter, not really. Power fluctuates a fair bit on any real road surface so trying to hold a wattage to a single watt is almost impossible. I also don't stare at my stem with the intensity of Froome so a general band of band of watts +/- 10/15 of target is my goal. Now I am waiting so someone to say that on their SRM they sit on exactly their target wattage within 0.5W and notice no fluctuations over a regular road as they have their legs so well tuned to road irregularities. Activate powermeter trolls now.
PostPosted: Mon Jul 21, 2014 11:09 pm
Here's another way to look at it: as a complete drivetrain:
SRAM Red 2013 Quarq - 793g
HSC BB w/o Sleeve - 81g
Speedplay Ti Zeros - 164g
Total = 1,038g
Price = $2,000 + $110 + $335 = $2,445
THM M3 SRM w/ FSA Compact Rings - 698g (cyclingtechblog)
THM English BB - 72g (according to Fairwheel)
Total = 934g
Total Cost = 2,745 (from SRM) + $160 (Praxis) + $335 = $3,240
THM M3 w/ Spider - 384g
Praxis Rings plus bolts - 130g
THM M3 English BB - 72g
Garmin Vectors - 350g
Total Weight = 936g
Total Cost = $996 + $160 + $1700 = $2,856 (THM from R2-Bike)
Rotor PowerMeter Compact w/ Praxis Rings - 761g
Rotor BSA 30 BB - 96g
Total = 1,021g
Price = $90 + $2,400 + $160 + $335 = $2,985
No Powermeter
Total Weight = 750g
Total = $996 + $160 + $335 = $1,491
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Tue Jul 22, 2014 12:49 am
Hollowgram stages
SISL2 compact 484g
+ stages arm (170 SI arm as SISL2 unavailable currently - 124g SISL2 arm weight) = +46g
+HSC BB w/o Sleeve - 81g
+Speedplay Ti Zeros - 164g
= 775g
$975 + $800 stages + $110 + $335 = 2220.
PostPosted: Tue Jul 22, 2014 1:09 am
SRAM Red drive side + Rival w Stages left side (w eBay purchases)..
SRAM Red 53/39 GXP exogram rings drive side only: 474g
SRAM Rival left arm w Stages: 230g ( :( )
VCRC ceramic GXP BB: 93g
Speedplay CrMo w aftermarket Ti spindles: 160g
= 957g (182g heavier than Hollowgram combination posted above)
SRAM Red GXP $230 (new eBay) + Rival w Stages $500 (almost new eBay) + $89 VCRC (new eBay) + pedals $129 + $75: $1023
Note SRAM Red cranksets are around $290 now. And Rival arms are closer to retail $700. I was lucky.
PostPosted: Tue Jul 22, 2014 1:51 am
I would echo what Showdown said. Started with a PT and it was a good introduction but limiting. Then went to wired SRMs. These were bulletproof, reliable, and consistent but eventually wanted to get away from wires. Had 3 Quarqs after that. Absolutely agree that they are very good products with exceptional customer service. I never had an issue with any of mine. Just recently moved to Stages as I like the flexibility of the new 9000 cranks and I like how inconspicuous it is. Also doesn't hurt that it's lighter.... I don't have a lot of experience on it yet but so far its been really good and the numbers aren't out of line with what I would expect.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
PostPosted: Sat Jul 26, 2014 5:29 am
I took the weight penalty and went with the Power 2 Max based off of DC Rainmaker's review that "it just works."
It's performed flawlessly for the last 6 months in all kinds of conditions.
PostPosted: Sat Jul 26, 2014 11:24 am
As the author of the original content on CPL I wanted to chip in and say that, while it's one of a range of data people find interesting, I don't think weight should feature very highly on the list of priorities when choosing a power meter. It's a tool to help do the job of improving your watts/kilo way beyond any small weight penalty so the considerations should be more in terms of accuracy, reliability, usability, maintainability. I encourage people to think about total cost of ownership. At one end of the spectrum SRM's are for life, fault-free-availability will be close to 100% of days and resale values are good. At the other end some units have low upfront cost but are questionable on other criteria.
cyclingpowerlab.com - performance modelling for cyclists & triathletes
PostPosted: Sat Jul 26, 2014 11:37 am
overgeared - well said, I fully agree.
PostPosted: Sun Mar 20, 2016 2:26 pm
has anyone tried the lightning road crank with the powertap chainrings?. if the lightning road crank is really 381g and the chainrings are really 120g, this seems like it might be the lightest option?
There are no new unread posts for this topic. power2max power meter
bikeracer99
35
3669
Thu Mar 30, 2017 6:12 am
PinaF8 View the latest post
There are no new unread posts for this topic. Power meter lifespan
stormur
7
1068
Sun Aug 20, 2017 2:55 pm
RyanH View the latest post
There are no new unread posts for this topic. Power Meter For Campagnolo
[ Go to page: 1 2 3 4 ]
lw11
46
5717
Sun Jul 23, 2017 11:34 pm
Mockenrue View the latest post
There are no new unread posts for this topic. Shimano Power Meter
cunn1n9
Thu Aug 03, 2017 10:48 pm
cycleboyco View the latest post
There are no new unread posts for this topic. Lil help w/ old SRAM (Red?) power meter?
Kidtreo
Fri Aug 18, 2017 4:34 pm
sungod View the latest post
Users browsing this forum: Bing [Bot], corky, eaglejackson, eric01, grumpier, Kaben, Massi and 46 guests
