It is currently Tue Jun 27, 2017 4:57 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Jul 09, 2014 8:36 pm
The latest 3T ergonova has internal cable routing. Or, at least the carbon version has.
I was wondering if there is a trick to stop the cable from rattling? I will only running brake cable, no shifters.
I was going to just wrap the bar tape a little pass the lever and leave the top bare... Now that you don't need a piece of tape to hold the cable near the stem thanks to internal routing.. is that how you would wrap it?
Here is a picture that I found.
PostPosted: Wed Jul 09, 2014 8:48 pm
Hey that's my picture! That's actually a Tornova bar but I suppose the routing will be similar. I didn't do anything other than run the cable through it and it has never rattled. It's actually a really tight fit and the housing will press up against the inside of the bar keeping it from rattling. The trick to routing it is to run your cable through first and then let the housing follow it through. Trying to route the housing first is next to impossible.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Wed Jul 09, 2014 9:03 pm
Oh nice :)
thanks google images.
I will only have a brake cable though so I figure the fit will be loose if I don't tape up to the second opening.
I think I can use a piece of silicone hose to cushion the cable itself.
It comes with some plastic tubes already to insert the steel cable through, the insert the housing like you mentioned.
PostPosted: Wed Jul 09, 2014 9:44 pm
I run the brake cable as well as a Di2 (smaller e-tube wire) through there. Silicone might be a good idea though if it's not as tight as the one I have.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Thu Jul 10, 2014 5:40 am
Mount little baby zip ties on the e-wire so they are clamped hand-tight on the e-wire and the tail is sticking straight out, and push them through the hole along with the e-wire. They will try to expand and push the e-wire against the side of the tubing. No noise and no wear from vibration. Do the same with frame tube noise.
PostPosted: Fri Mar 04, 2016 2:17 pm
How does this work with D-A 9000 levers/levers?
There are no new unread posts for this topic. Aero Handlebar Internal Cable Routing
KrayzieJ
Wed Sep 28, 2016 9:13 am
polaris View the latest post
There are no new unread posts for this topic. Scott Addict SL Cable Stops for internal cable routing
kulivontot
Sat Sep 10, 2016 4:33 am
kulivontot View the latest post
There are no new unread posts for this topic. Internal cable routing problem.
Jml
Wed Sep 28, 2016 10:00 am
Jml View the latest post
There are no new unread posts for this topic. Zipp sl70 aero internal cable routing help
A2ON
12
1354
Fri Jul 22, 2016 8:38 am
A2ON View the latest post
There are no new unread posts for this topic. Compressionless brake housing for internal routing
bikewithnoname
Sun Apr 16, 2017 7:43 am
bikewithnoname View the latest post
Users browsing this forum: dynaserve, Google Adsense [Bot], Hexsense, Rippin, Rush, spytech and 40 guests
