It is currently Thu Jan 19, 2017 12:14 pm
Post new topic  Reply to topic  [ 12 posts ]
 Post subject: Sidi Wire half sizing
PostPosted: Wed Jul 09, 2014 6:45 am
I have a pair of Sidi Ergo 3's Speedplay sole size 44 and looking to upgrade to the Sidi Wires as I find the Ergo 3's are too narrow in the toe box. Are the half sizes a bit longer or is it the same length sole as the 44's but a wider toe box . Thanks in advance
PostPosted: Wed Jul 09, 2014 11:14 am
My experience is that lengthwise they are the same. I usually wear a 45 and tried a 44.5 in Wire and they were notably "shorter"
In fact I have not returned them, so I could measure against a mates 44s if you want?
PostPosted: Wed Jul 09, 2014 12:12 pm
The answer is on the sidi site. 3mm longer and proportionally higher volume.
PostPosted: Wed Jul 09, 2014 12:46 pm
And I think the difference in the half sizes is in the upper. I believe that the full and half size use the same sole, with the half size having the size increase built into the upper.
PostPosted: Wed Jul 09, 2014 5:03 pm
You should be fine in 44.5. I'm exactly the same in that sizing and have owned both the Ergo 3 and have Wires now and the 44 was too small in the toe box just like you.
PostPosted: Wed Jul 09, 2014 6:45 pm
Well ,
Even when the same sole is used the inside of the shoe can increase in length.
dj97223 gave already the correct answer.
Btw although I can use some little more room in the toebox of the Ergo's , the Wire is too roomy for my feet.
They better should make the Ergo-shoe little more round, especially at the point of your big toe.
PostPosted: Thu Jul 10, 2014 2:25 am
Woah too bad (edit - for some!) they made the Wire bigger in the toe area, the Ergo 3 fits me perfectly. Glad I read this before buying the wire online. That must be why they kept the Ergo 3 in the lineup for 2014.
PostPosted: Thu Jul 10, 2014 5:04 am
I have gone from Ergo 2 to Wire in 44. I find that there is more room around the toes and that the wire mechanism evenly tightens the whole fore-foot of the shoe so that it feels equally secure to the Ergo. You therefore might find staying with a 44 OK.
Only thing I miss about the Ergos is the ability to easily tighten the main buckle through an over-sock with full-finger gloves. This is still possible, but trickier, with Wires.
PostPosted: Thu Jul 10, 2014 4:00 pm
Does anyone know who stocks the Sidi Wire in half sizes? I cannot find a vendor with them in stock.
PostPosted: Sat Jul 12, 2014 6:02 pm
I bought the Sidi Wire 44.5 but found them to be the same length as the Ergo 44's but with more toe room. The 45's were way too big
PostPosted: Sat Jul 12, 2014 9:25 pm
I changed from Ergo 1 size 43 to Wire Vernice 43.5 (CRC was vendor) and I'm really pleased as now I have that little bit of room round toes especially when on hot summer ride and feet swell slightly ... wish I'd done this sooner!!! :)
Nitemare
PostPosted: Sat Jul 12, 2014 10:36 pm
biketiresdirect.com has them in half sizes.
There are no new unread posts for this topic. Sidi wire air Vs Fizik R1B Vs Rapha GT
snowdevlin
Thu Mar 24, 2016 11:05 am
snowdevlin View the latest post
There are no new unread posts for this topic. Attachment(s) How to wire up new Bar-End Junction A for Di2 (EW-RS910)
bikerdan
41
3034
Wed Jan 18, 2017 7:47 pm
Zoro View the latest post
There are no new unread posts for this topic. Sidi shot fit vs wires?
Cheers!
Sun Dec 25, 2016 12:06 am
toiyuet View the latest post
There are no new unread posts for this topic. Sidi Genius 5-Fit Carbon Road Shoes
ajmit3
Fri Sep 16, 2016 12:05 pm
ajmit3 View the latest post
There are no new unread posts for this topic. BMC TeamMachine Sizing
stefan416
Wed Aug 10, 2016 4:18 am
2lo8 View the latest post
Users browsing this forum: andylav, Bing [Bot], djcharlou, elfuinha, JackRussellRacing, kenw, Mockenrue, Yahoo [Bot], zirxo and 24 guests
