It is currently Thu Jan 18, 2018 10:58 pm
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: 3t arx ii stem
PostPosted: Mon Jul 07, 2014 5:43 am
Does anyone have anything good to say about the arx ii?
The arx 1 tested well at fairwheelbikes but the 2 now has the 2 bolts closer together and 1 bolt for the steerer.. I was wondering if it might be a downgrade.
On the other hand.. one store listed arx made in china and arx ii made in taiwan.
Arx ii using t25 is more resistant to stripping out even if that means a new tool is needed
 Post subject: Re: 3t arx ii stem
PostPosted: Mon Jul 07, 2014 10:36 am
I have a ii. Nothing much to compare with except a old Pro stem from 6 years ago. Much stiffer... No issues with the close bolt design though prefer the look if the mark 1. Yes the t25 is a pain in the backside... Good thing it is not something you adjust often.
PostPosted: Mon Jul 07, 2014 6:52 pm
What I don't understand is why, with such low torque specs, are more manufacturers starting to use Torx-head bolts on stems? On most stems, you're only supposed to torque the bolts to 6 Nm or so.
It's a hassle when you want to make adjustments in the field. I have multitools with hex drivers, but none with Torx. Do we now have to carry tools for both hex and Torx?
In meiner Kette fehlt kein Glied, wenn die Lust von hinten zieht.
PostPosted: Mon Jul 07, 2014 7:21 pm
Was stiffness an issue with the first iteration?
PostPosted: Mon Jul 07, 2014 8:20 pm
On most stems 5 or 6Nm is the maximum not the target. Which is probably why 3T chose to go with Torx
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Tue Jul 08, 2014 2:23 am
The original arx stem bolts in steel or ti should never strip if torquing to recommended settings and lubing threads.
PostPosted: Tue Jul 08, 2014 6:12 am
Max, not recommended
There are no new unread posts for this topic. Ti Stem bolts
misterq
21
2076
Thu Nov 02, 2017 8:48 pm
misterq View the latest post
There are no new unread posts for this topic. Th tibia stem
richscott
Mon Apr 17, 2017 1:34 pm
KCookie View the latest post
There are no new unread posts for this topic. Help me slam my stem
[ Go to page: 1 2 3 4 5 ]
Mep
71
6611
Thu Apr 06, 2017 8:49 pm
darnellrm View the latest post
There are no new unread posts for this topic. Canyon Stem
chunboon
Wed Jul 19, 2017 7:04 pm
MayhemSWE View the latest post
There are no new unread posts for this topic. Attachment(s) Bontrager XXX Stem
benhama
9
1316
Wed Aug 30, 2017 9:55 am
benhama View the latest post
Users browsing this forum: Alpine318is, Baidu [Spider], bilwit, bm0p700f, dorin, Google Adsense [Bot], jch3n, tokyodrift69, wheelbuilder and 48 guests
