It is currently Tue Mar 28, 2017 5:18 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sun Jul 06, 2014 4:49 pm
I am looking at the FSA seatpost and it says it is Di2 compatible, but it weights more than the previous non-Di2 version.. is the Di2 adapter just at the end of the seatpost? OK to cut off part of the seatpost if I am not needing this feature?
PostPosted: Mon Jul 07, 2014 9:49 pm
I don't think it's clear what you're asking. Try rephrasing your questions.
My favorite components are the ones I never have to think about.
PostPosted: Mon Jul 07, 2014 10:05 pm
Yes, let's try again.
PostPosted: Tue Jul 08, 2014 2:16 am
FSA still makes that post in a non Di2 version, just have to look around a bit more. So to try and answer your other question, as long as cutting down the post still allows for the minimum required insertion length, then yes, it can be cut off. Simply take note of where the stock FSA minimum insertion line is printed on the shaft and the insert is a tad shorter that. I had to cut the FSA K-Force Sb25 post even though I needed the Di2 insert, the post was too long when inserted into the seat tube of my wife's Scott Solace and I was able to reuse the insert once it was cleaned of the bonding residue without issue.
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. Best Way to Remove Oxidation from Spoke Nipples
ipenguinking
Mon Oct 17, 2016 2:53 am
TheKaiser View the latest post
There are no new unread posts for this topic. How to remove Reynolds freehub Strike SLG wheelset?
poppiholla
Fri Jan 20, 2017 11:52 am
poppiholla View the latest post
There are no new unread posts for this topic. Any easy way to remove white logos on carbon rims?
Shrike
Sat Jan 28, 2017 12:11 am
Broady View the latest post
There are no new unread posts for this topic. Carbon seat + post : Remove bracket/rails and attach seat directly to post - bonding?
alcatraz
Sun Oct 23, 2016 4:07 am
KarlC View the latest post
Users browsing this forum: Baidu [Spider], bipedzed, Google [Bot], IhmeKameli, MarginalChains, nycebo, Shmitt and 44 guests
