It is currently Sat Dec 16, 2017 10:11 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Thu Jul 03, 2014 6:15 pm
I'm using a 10 speed Di2 setup, will any 10 speed Shimano cassette work or is the Di2 cassette specific to this drive?
PostPosted: Thu Jul 03, 2014 6:23 pm
Any 10s cassette (Shimano or SRAM) will work.
PostPosted: Thu Jul 03, 2014 11:25 pm
Thank you
PostPosted: Sat Jul 05, 2014 8:27 pm
i am using a XX 11-36 sram cassette with , on front, a 42T single ring only
Di2 7970 10 speeds without modifications, it works flawless
http://eliflap.it/
PostPosted: Sun Jul 06, 2014 10:59 am
When i had 7970 I used a KCNC Ti 12-27 worked perfect
PostPosted: Sun Jul 06, 2014 5:10 pm
most any of the compatible cassettes like KCNC / Recon will work too and you're saving dollars and grams in some cases...
Also, run a new (or new-ish) cassette if you're running a new chain / drive system
charles@pezcyclingnews.com
There are no new unread posts for this topic. Attachment(s) Shimano Compatibility
Valbrona
Mon Jan 02, 2017 10:55 pm
ooo View the latest post
There are no new unread posts for this topic. power meter Q again, compatibility
Boshk
Mon Jul 24, 2017 5:31 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. 9170 shifters compatibility
hannawald
Mon Oct 23, 2017 11:22 am
hannawald View the latest post
There are no new unread posts for this topic. Sram Red BB386 crank arm compatibility
Jian81
Sat Dec 16, 2017 7:21 am
Hexsense View the latest post
There are no new unread posts for this topic. Praxis Zayante Crankset - BB compatibility
Stolichnaya
Sun Aug 27, 2017 1:14 pm
Attermann View the latest post
Users browsing this forum: Alexa [Bot], chris47, Feddesman, JohnHinMD, L3X and 27 guests
