It is currently Fri Jan 19, 2018 7:01 pm
Post new topic  Reply to topic  [ 72 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Tue Jul 01, 2014 11:53 pm
My 2 year old Tune Mag 170 hub broke while sprinting over an overpass today. At first I thought it was a broken spoke, when I got home (a couple of minutes later), I saw two spokes hanging from the rim. Then I noticed it, the DS flange completed broken off. :cry:
When Troy Watson (Ligero Wheelworks) worked at his own shop, he built a wheel set for me with Mig 70 and a Mag 180, after a year and a half it began to creak. Sent it to Fairwheel Bikes and they fixed it with the Tune "fix". It creaked again so they took the hub in as a trade-in and offered me this Mag 170.
The wheel was then rebuilt around the new Mag 170, again by Troy Watson for Fairwheel Bikes, built with Sapim C-Xray and Alu Nipples and laced to Nio30 rims.
I'm bummed, I like the hub. This is the first time I've broken a hub flange in over 25 years of riding and racing. I guess I'll just give them a call and see what they say about it.
https://www.flickr.com/photos/23398613@N08/14553909985/
http://ddubcustomsportswear.com
PostPosted: Wed Jul 02, 2014 1:49 pm
As a sprinter with a set of 56mm tubulars with this hub...doesn't make me feel any better.
Time for them to do a recall along with the Alchemy ORC UL....
PostPosted: Wed Jul 02, 2014 2:08 pm
one failure and you want to recall thousands of hubs?
Please stop using quotes for replies.
PostPosted: Wed Jul 02, 2014 2:10 pm
Resident Pro
that's a bummer. what do you weigh?
PostPosted: Wed Jul 02, 2014 2:29 pm
Between 165-170lbs. It was a 5% grade, about 60 meters long and I was in my 53/12. I hope to talk to them today, I don't know what to expect but am hoping for some good news. The rear wheel is 28 spokes.
no need to quote. this is a reply. you can find that button right next to the quote button. Thanks!
PostPosted: Wed Jul 02, 2014 2:33 pm
Resident Pro
we are the same weight. i hope my mag 170 does not break either.....
PostPosted: Wed Jul 02, 2014 3:52 pm
Good news! Fairwheel Bikes got back to me via email. They said that they have sold over 500 of the Mag 170 hubs and have only seen one other flange break. Although I am outside of my 2 year warranty by 3mos, they offered to either a) send me a new hub or b) have me send them the wheel and they will rebuild it around a new 170 hub at no charge. Fairwheel Bikes proves again, they have top-notch customer service. Their service is much appreciated. I'll be sending the wheel back in a couple of days.
:beerchug:
and another quote changed to a reply.
PostPosted: Wed Jul 02, 2014 3:54 pm
Resident Pro
good to know! i've had two wheels built by fairwheel with the tune hubs....
PostPosted: Wed Jul 02, 2014 4:08 pm
Odds are, that you won't have the same thing happen to your hubs. :thumbup:
Wow, already spend 10 mins cleaning only this topic.
PostPosted: Wed Jul 02, 2014 7:23 pm
Yeah, that is exactly what happened with Alchemy ORC UL hub. 1 failure, research and testing performed, recall all of them.
PostPosted: Wed Jul 02, 2014 8:01 pm
Thats because the bolt that failed did not pass the more rigourous testing Jeremy put it through so I think Jeremy expected fatigue failure of many hub in time hense the recall. One failure on the tune hub could mean an inclusion in the metal used in the hub flange it does not mean there is anything wrong with the design. Two completely different situations. If I was tune I would not be recalling just yet.
www.thecycleclinic.co.uk
PostPosted: Mon Dec 08, 2014 3:29 am
Well, the replacement hub started to develop a creak a few months later. Sending it back now to have FB look at it. All of the benefits on the 170 don't outweigh the hassle of spending money shipping them back for fixes :x
PostPosted: Tue Dec 09, 2014 2:55 am
bummer... I'm really hoping that the creaking was solved in the 170... because eventually I planned to have some Sl23 laced up with mig/mag combo.
I planned on using a 28h in the rear.
PostPosted: Tue Dec 09, 2014 2:49 pm
I'll post an update when FB gets the wheel back and informs me on what they found. If history repeats itself, it'll be blamed on some issue not related to design or construction.
PostPosted: Tue Dec 09, 2014 3:39 pm
I'm surprised that a broken Tune flange is news to you - in the shop where I used to work, there is box full og broken Tune hubs, almost all have this failure. There is another box full of broken PMP and FRM hubs. Actually Tune, PMP and FRM work quite well for their weight, just don't expect years and years of service, especially if you can produce tons of watts pedalling!
The broken hubs can serve as donors for bearings and axles, the former are sometimes the original one Tune put in, so they outlast the flanges!
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Broken Campagnolo Brake Shoe Retainer Springs on Record Brakes..
3Pio
Mon Mar 06, 2017 4:39 pm
Butcher View the latest post
There are no new unread posts for this topic. Tune freehub
steelme
7
897
Wed Apr 12, 2017 9:51 pm
steelme View the latest post
There are no new unread posts for this topic. Speedplay Tune ???
1spd
16
2147
Thu Apr 06, 2017 1:19 pm
kode54 View the latest post
There are no new unread posts for this topic. Re-covering tune speedneedle
Martin.F
Thu Mar 02, 2017 2:03 am
Fixie82 View the latest post
Users browsing this forum: andreszucs, Baidu [Spider], Catagory6, Chris3g, chrispino, dcorn, Delorre, rsantos450, SpartacusCZ and 43 guests
