It is currently Fri Feb 24, 2017 12:16 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Sat Jun 28, 2014 10:53 am
isharamet wrote:
mattr, no visible damage yet.
Of course not, the damage will be on the seats in the frame. The bottom bracket needs to come out to check.
Tbh, with something like that, I'd have had it straight back to the shop. You've got to wonder what else they've pushed in cock eyed
PostPosted: Sat Jun 28, 2014 1:12 pm
I had the same problem on my Supersix Evo
After only 200 kms I had heavy clicking and one cup went loose (but not as much).
So I took everything off and swapped the groups with my Ti bike (with no PF30 ).
The Praxis adaptator was not available at this time.
On the loose side I could press the adaptator in by hand, so no wonder it came loose.
Went with that for Shimano : http://wheelsmfg.com/products/bottom-br ... ckets.html
So I would first recommend to take it appart to check what is wrong (fitting of the adaptator or diameter of the frame's bb).
PostPosted: Sat Jun 28, 2014 2:02 pm
Buying a new buy may come with a warranty. They should take care of your problem. My guess they are not going to resolve it quickly since there is going to be a lot of trial and error to see what fits on your bike.
Search the forum and the net. You will find there are many people just like you with problems of the cups coming out. Praxis, C Bear, Parlee are just a few company's that make different style adapters that solve the problem. Again, other company's have solved the problem with locktite and epoxy. The fact is that it is a poor concept.
I have yet to have a problem on my PF30 bike with Campy crank. I studied this issue before the build and found that the Parlee was the lightest way that would work for me. Praxis was up there too with my decision, but they were not making it at the time and their timeline was a lot like the Garmin Vector.
Either way, there are many with the same issue as you and with a little searching, you will find the answer for your problem with a lot less hassle. It might be costing you more money, but at least with a lot less headaches.
One more thing, the mechanic may be an idiot, but he did not design it. He just put it together. Even if he did it correctly, it could still come out. Be nice to him until he has proven he's an idiot.
PostPosted: Tue Jul 01, 2014 1:52 pm
Butcher, since shop is 1000 km away it is not an option. It's just easier to do it by myself.
Just removed my cups. This is how shell look like (slight marks from cups on both side):
Guys, need your advice on cleaner. Is it safe to use Loctite 7063 to clean BB shell (raw carbon, no painting/coating)? Thanks
PostPosted: Tue Jul 01, 2014 2:01 pm
Are you still trying to make the campy cups work ? They won't.
PostPosted: Tue Jul 01, 2014 2:09 pm
I think I have no options here since I live in Belarus, and Praxis don't ship its BB here. Same story with Parlee.
PostPosted: Tue Jul 01, 2014 3:13 pm
The marks are simply a result of cups having been installed. Only very accurate calipers will tell whether the tolerances are out of spec. The good thing is that there is no deep gauging and the surface is clean and smooth.
I would recommend a non-solvent based degreaser (Loctite 7063 is solvent-based). BB looks quite clean already....you just want to get any grease residue out.
Because your BB shell has no cut outs it is ideal or the Loctite method (some shells with cut outs may not have sufficient surface area to contact length of BB cups). Remember, apply liberally, press in cups, and let them cure for about 24 hours with press installed. Good luck
EM3
______________
My 2013 Cervelo R5
PostPosted: Tue Jul 01, 2014 8:17 pm
em3, thanks. Just installed cups with Loctite 641 and 7649 pirmer leaving the press in. Hope for the best)
PostPosted: Thu Jul 03, 2014 10:51 am
Just did a 66 km ride and here the results:
Small gap on drive side (0.5 mm or less) and non-drive side is ok (I think).
So what do you recommend go for Praxis Conv BB? And should I ride my bicycle in such state?
PostPosted: Thu Jul 03, 2014 4:23 pm
As I said 2 or 3 times already these cups won't work. Period. Praxis maybe a solution.
PostPosted: Thu Jul 03, 2014 7:02 pm
Thanks. I'll go for Praxis. But since this is my only bike now, is it ok to ride it in such state, or better wait until I get Praxis BB.
PostPosted: Fri Jul 04, 2014 7:19 pm
bummer....you have three options:
1. Try a higher strength Loctite designed to fill larger gaps and with higher yield strength (e.g. 609 or 680)....641 did not work for me the first time on my BBRight press fit with Campy cups and I and to move up to 609, which has worked well.
2. Praxis
3. Get a warranty frame and engage Loctite method on fresh far before any cups are installed
Good luck.
EM3
______________
My 2013 Cervelo R5
PostPosted: Thu Aug 28, 2014 9:52 am
With help of good guy Mark (aka Butcher) I solved all my problems with PraxisWorks Conv BB. It's the ultimate solution for press fit bottom brackets and Campy UT cranks. Did about 1500 km since installation without any problems.
PostPosted: Thu Aug 28, 2014 2:20 pm
Glad you got this sorted and pleased to see that the WW community helped you out!
For what it's worth I've put over 5k miles on the Campag PF30 cups with no issues whatsoever, I really think it comes down to the precision of the initial install and tolerance of the frame.
Enjoy the ride!
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2 'dales SM1000 and Habit SE
PostPosted: Thu Aug 28, 2014 2:58 pm
I'm glad to see that you now get to ride your bike without anymore noises.
By the way, I would not have trusted that guy, he's a Butcher. But his wife is a real sweetie and made it all happen.
There are no new unread posts for this topic. Which campagnolo bottom bracket record for SR 11 groupset
fh8425
Wed May 18, 2016 2:39 pm
ergott View the latest post
There are no new unread posts for this topic. What bottom bracket do I have?
G6612
Thu May 05, 2016 8:58 pm
Calnago View the latest post
There are no new unread posts for this topic. Which GXP bottom bracket?
cnyn
Wed May 11, 2016 6:44 pm
topflightpro View the latest post
There are no new unread posts for this topic. Need help on bottom bracket
poppiholla
Tue Jul 05, 2016 9:38 pm
poppiholla View the latest post
There are no new unread posts for this topic. Campagnolo C-clip on drive side EPS Ultra Torque cups
58teeth
Fri Jul 01, 2016 11:26 pm
58teeth View the latest post
Users browsing this forum: Baidu [Spider], beanbiken, Exabot [Bot], jeffy, nobuseri and 36 guests
