It is currently Fri Jan 20, 2017 1:23 pm
Post new topic  Reply to topic  [ 153 posts ]  Go to page Previous 1 2 3 4 511 Next
PostPosted: Thu Jun 26, 2014 7:06 pm
A little bit more rounded but nothing radical. I don't like the external nipples... Anybody ever had to true their Boras?
tumblr
PostPosted: Thu Jun 26, 2014 7:36 pm
Was wondering when they'd update the Bora II's. Can't tell if they're actually wider at the rim, but I hope they didn't go too much wider, they are tubulars after all so just give enough width and rimbed shape to properly glue a wider tire and all is good. Hubs look a little less sexy than the current version imo, but i'm sure they'll be just as smooth. I do prefer the outboard nipples for a couple of reasons. 1) easier to true if you need to (I've only ever broke one spoke on a Bora but it's still a pain to have to remove the tire to replace it. And 2) Even though you can't see the rim bed in these photos I would guess it's the same as the Bora 35's... meaning no holes, which makes it a breeze to brush the glue over without trying to go around the holes and avoid getting globs of glue inside the rim. So even though hidden nipples would undoubtedly test better in the aero department, I'm glad Campy is giving the nod to practicality over aero in this case. I really like the overall shape too.
I had a pair of Bora 35's to look over for a few days and they just felt so so solid. Very impressed.
Geez... with the new 2015 changes to the group, and a set of these new Boras... Campy looks to remain the sexiest group on the road.
Can't wait to try a set and see if the wider rounder inner profile really makes that much of a difference to the stability in cross winds. According to the ENVE folks and others, it seems to. I found that merely going from a 23mm tire to a 25mm tire also increased the stability... so now I just want to know which has the bigger effect.
And although this has nothing to do with the wheels, if you want to go with direct mount brakes and get them aero... then the way depicted on this Canyon is the way to go, as opposed to hiding them under the bottom bracket. Just a much better functional placement.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Thu Jun 26, 2014 7:42 pm
Anyone has the actual dimensions ?
PostPosted: Fri Jun 27, 2014 10:26 pm
The reason the brakes are seatstay and not b/bkt/chainstay mounted is because pro team mechanics don't like the under chainstay style as it's slightly akward to readjust "on the move" during races.
PostPosted: Sun Jun 29, 2014 2:33 pm
Yes - but only after a crash. They are stout.
Anyone know if the 35mm rim is fattening up. We need that fatter with the Ultra hubs pls.
PostPosted: Sun Jun 29, 2014 5:59 pm
Looks like not only Boras will get upgrades for 2015, the Fulcrum Racing Zero have a new braking surface treatment so expect at least some new Shamals too :D
http://www.wiggle.co.uk/fulcrum-racing- ... t/?lang=en
The specs list them at 25mm wide, nice!
PostPosted: Mon Jun 30, 2014 8:43 am
Intresting: Carbon brake pads must be used on the aluminium Fulcrums....
It looks good.
The Valverdes set up is weird:
- Campa groupset with Dura Ace brakes (I understand why....I am just surprised Campagnolo allowed them to use it)
- Boras rims with Scirocco hubs! (the oficial ULTRAs will definatelly have the carbon ones used on Bora ultra 35)
PostPosted: Mon Jun 30, 2014 10:31 am
More information on the Fulcrum Racing Zeros for 2015:
http://blog.wiggle.com/2014/06/29/win-a ... wheelsets/
PostPosted: Mon Jun 30, 2014 2:39 pm
Those are not Scirocco hubs.
As stated further up thread they are Bora One hubs (or very similar). They look identical to the hubs on my Bora Ones
Incidentally these also look very similar to the hubs on Zondas, Scirrocos etc etc ... It's the internals that are different to everything below Zondas where you drop into cartridge bearing land rather than cup and cone.
Having owned tons of the Campag range of wheelsets there is a big step up/ down at that point
PostPosted: Mon Jun 30, 2014 6:42 pm
I have Bora ONE wheels and my hubs are definatelly different from the ones on the pictures above!
BOra One hubs:
http://www.campagnolo.com/jsp/en/wheels ... tid_10.jsp
PostPosted: Mon Jun 30, 2014 10:32 pm
The blog say the Zeros are 25mm deep on the front and 30mm at the rear but the link you posted xplaza has a different spec. One is wrong or both who know until they arrive.
www.thecycleclinic.co.uk
PostPosted: Tue Jul 01, 2014 2:02 pm
I stand corrected if they are not Bora One hubs ... though that doesn't make them scirroco hubs either - which would be very weird as they are low end cr@p.
PostPosted: Tue Jul 01, 2014 5:29 pm
I think they've messed that zero description up a but, I reckon they're 23mm wide with height being 25/30. I really hope they make a tub version!
Looks like Campy saw all the money that Mavic have been raking in w SLR. Ran my R-SYS SLR tubs in horrid conditions at Grand Bo on Sunday and easily out descended everyone, they are a massive advantage in bad weather. My skilz were about equal to the othes.
As for the hub debate earlier, I had a pair of Bora special edition zero.7 off the Wilier w ceramic bearing and that same hub shell. They were still insanely good despite the ugliness.
PostPosted: Wed Jul 02, 2014 12:07 pm
Would've expected the blog to highlight the fact that they are now wider.
Pics don't look like they're 23 or 25mm. I expect they are the standard 20.5mm width.
I'll be pleasantly surprised if I'm proved incorrect!
There are no new unread posts for this topic. Bora 35mm One brand new - or - Bora 35mm Ultra used
ronderman
23
2629
Sat Nov 05, 2016 4:51 am
karng View the latest post
There are no new unread posts for this topic. Bora Rim Weight
prglewis
Sun Oct 02, 2016 9:34 pm
prglewis View the latest post
There are no new unread posts for this topic. Adjusting a Bora hub
havana
Fri Mar 18, 2016 1:33 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Campagnolo Shamal C17 or Bora One 35 ?
fignonsbarber
19
4848
Thu Jun 30, 2016 11:15 am
EvilEuro View the latest post
There are no new unread posts for this topic. 2017 bora one and ultra wheels?
karng
Wed Nov 02, 2016 4:42 am
Shonn View the latest post
Users browsing this forum: Google [Bot], stormp, victorduraace and 22 guests
