It is currently Tue Feb 28, 2017 4:05 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu Jun 26, 2014 12:26 am
I've had some adjusters move while riding. It takes a while to figure out why my derailleur keeps going out of adjustment.
The sram one may be hard to turn while riding but at least it stays in place.
BTW if you have adjusters that you suspect are moving you can mark them with a sharpie to see. On some you can disassemble and stretch the spring out a little. That can help for a while but the spring will sack again and lose tension.
PostPosted: Thu Jun 26, 2014 12:44 am
I use one of these jagwire ones (below). They work well as have a long travel so can really ramp up the cable tension as the SRAM Yaw FD needs a tonne of cable tension to work well I found.
Eric i too noticed the barrell would unwind itself so once I have set the correct tension I use araldite (epoxy glue) - just one glob to hold it in place. The advantage of this over superglue is it can be easily removed with pliers and is too viscous to flow into the gap between the inner and outer piece of the barrel adjuster. I still wish frames used downtube mounted cable adjusters, inline adjusters are a step backwards.
http://www.jensonusa.com/!i8TK-N3WT4lo! ... yvWqTw_wcB
Evo 5.63kg SL3 6.66 viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Thu Jun 26, 2014 3:33 am
I use the same Jagwire ones as above, front derailleur only. The weight addition is negligible and I like the ability to fine tune the tension and not have to mess around with clamping and re-clamping the FD cable. I position them low on the cable run so they sit just a little bit in front of the headtube, almost where the cables cross (I run my shift cables routed to the front of the bars).
PostPosted: Thu Jun 26, 2014 6:48 am
The SRAM one works fine for me. Agree that it's almost a necessity to have since Yaw 22 derailleurs are an absolute pain to adjust initially.
I doubt you'll find a better functioning one, there's just so much tension on the cable that you can only adjust it when on the small ring.
If the adjuster can be turned under the cable tension needed for the big ring, it won't stay adjusted with the lower tension on the small one,
PostPosted: Thu Jun 26, 2014 3:38 pm
Yup, I was only able to adjust it when on the small ring. Needs an insane amount of tension. Are you able to turn yours with one hand? I can barely turn mine with two hands. The top of the barrel doesn't stay put and I sometimes need to use pliers to hold that end so that I can turn the barrel. I think it might have to do with the Aican Bungarus housing being smaller than the top end, so it's not able to grip the housing.
6.24kg CAAD10
PostPosted: Thu Jun 26, 2014 7:49 pm
What about here.... http://www.torontocycles.com/Selling/Derailleur.html
PostPosted: Thu Jun 26, 2014 8:10 pm
I don't see an inline adjuster on that page.
6.24kg CAAD10
PostPosted: Thu Jun 26, 2014 9:04 pm
The only ones I found on the net were these and they are not that elegant.
http://www.sram.com/sram/road/products/ ... l-adjuster
http://www.amazon.com/Jagwire-Inline-Ad ... DB8M9UQDG5
PostPosted: Fri Jun 27, 2014 3:12 am
I didn't have any luck with any of those.
My test is -if you can't turn it with a wet full-finger glove on the numb hand -it is not worth a hoot.
Here is my favorite: http://fairwheelbikes.com/alligator-bar ... -4829.html
PostPosted: Fri Jun 27, 2014 12:00 pm
Serge, that's a Frame Barrel Adjuster, not an inline adjuster.
Here's the ones I was referring to -
http://jagwire.com/products/v/Inline_Adjusters
CHA035 & BSA036 are light not too chunky unlike the BSA044.
The spring is quite strong in them but the belt and braces approach is to put a little low strength Loctite on the threads.
It can still be adjusted but stops it loosening on its own.
PostPosted: Fri Jun 27, 2014 2:20 pm
@5 8 5 Are those compatible with i-links and swift housings?
PostPosted: Fri Jun 27, 2014 2:55 pm
i-links yes. Sorry, don't know about Swift housing. What diameter is it?
PostPosted: Fri Jun 27, 2014 3:14 pm
5mm
PostPosted: Fri Jun 27, 2014 3:20 pm
It would depend on the size of the ferrules used. Just measured the adjuster and it's just a shade under 6mm at each end.
PostPosted: Fri Jun 27, 2014 5:40 pm
Have to try out the Jagwire. Is there a difference between the BSA036 and the CHA035 other than color?
The SRAM opening are too small for me to use the ferrules that came with the Aican Bunguras, so I run it without, but the housing is smaller than the openings, and the adjuster is not getting a good grip on the housing, so the entire thing turns. I have to measure the ferrules but I know the Aican housing is 3.8mm.
6.24kg CAAD10
There are no new unread posts for this topic. Experience C60 'high'
Daniel1975
Sun Oct 09, 2016 10:37 am
ajmojave View the latest post
There are no new unread posts for this topic. High compression bib shorts?
Allen254
13
1442
Tue Nov 22, 2016 6:21 pm
boots2000 View the latest post
There are no new unread posts for this topic. what clincher wheelset is best for high mountains
Enda Marron
11
1825
Wed Oct 12, 2016 6:00 am
hanchangjung View the latest post
Users browsing this forum: Benno, benzebub, Bing [Bot], bremerradkurier, gmarsden, iwantone, jfranci3, MoreRideTime, sungod and 25 guests
