BB help bb30 quarq into bb86
carbon337
by carbon337
hello, I've done a few searches but still cant get a definitive answer to this.
A friend is looking to upgrade from a specialized tarmac sl2 to either a Giant Propel adv sl or a scott foil team hmx fameset and new groupset.
He has a quarq riken but its BB30 that he ideally wants to reuse - are there any adapters that will allow him to get a bb30 quarq into either of these pf86 framesets?
Ive seen these http://rotorbike.com/products/road/bb86_40 by rotor but its a bit confusing.
by 5 8 5
This has come up before. The Rotor adapters will work but to accommodate the larger spindle the bearings are very small and not very durable.
I can't search at the moment but there are threads that cover this.
NiFTY
by NiFTY
As 585 said, Riken is not a true BB30. It will fit, but bearing life will be short as the bottom bracket is designed for a 24mm spindle and the riken has a 30mm spindle, the additional 6mm has to come out of space available for the bearings.
JensW
by JensW
the bearing should not be that thin considering that they have made the "press-in" a part of the bearing, BUT bb86 has a wider shell on the frame then bb30, så the problem can be that the spindle will be to short
NiFTY
by NiFTY
As already stated the Riken has a longer spindle as it is not a true BB30 crank.
grover
by grover
Buy a standard GXP crankset. Swap the spiders. Sell the Riken BB30 arms with standard spider on it.
