The holy grail of skewers
by TheDarkInstall
jpanspac wrote:No it doesn't.
1. I concede that the front wheel does not see any torque.
2. You are wrong in denying that there is no leverage applied to it during sprinting.
I think we are at cross purposes here. All good.
by mambo
The holy grail of skewers is the tool my friend in the US Mark Stemmy of Optimized Cycling Solutions has invented and is currently patenting to ensure that hub bearings are not overloaded when tightening the QR skewer!
Owner Cicli Schiavona - hand made, custom Italian carbon frames at prices you won't believe! ... 8745538716
by solarider
Where to grease skewers?
In my experience noise comes from the interface between the axle ends and the dropout because some lightweight skewers sacrifice clamping force for light weight. Check it is tight first.
Ultimately the 'best' skewer is one that holds your wheel firmly, has a smooth action, a good opening width to avoid lawyer tabs and is easy to use. It is hardly the heaviest thing on your bike (that's probably you BTW!), and the difference between a standard and light weight skewer is minimal.
For me, the 2000 vintage Record skewer takes some beating.
by Geoff
Light is fine (in which case I recommend Albert Bold's version), but for all-around use it is hard to beat the 'factory' offerings (either of Shimano or Campagnolo).
by bm0p700f
Holy grail of skewers, that Dura Ace or Campagnolo surely. Also there two Italian manufacturers that have solved the problem of overloading bearing when tightening Q/R skewers it is called a bearing preload adjuster. also you could just not over tighten the Q/R now there's a thought. I should patent the hand, brain and nerves -with this invention it is possible for any human to correctly tighten Q/R skewers. It is possible there will be other spin offs yet to be determined.
by fa63
To me skewers are not really the place to save weight (I know, it is blasphemous), so Dura Ace all the way.
by TheDarkInstall
Yeah, I am inclined to agree, which is why I wanted something a bit lighter, but not as fragile as the ones I had before which I rendered.
by GonaSovereign
QRs are one of the things that you should not fk around with. Shimano and Campagnolo are the best - they weigh more for a reason. The Tune ar14 (?) is basically the old American Classic design, which is OK. Sadly, external cam designs are not as good.
by BeeBee30
TheDarkInstall wrote:I currently use the Mavic skewers, and sometimes the Dura Ace ones, depending on how I feel that day, and I can go mental on them without so much as a whimper.
I sometimes ponder what jersey to wear but never found myself deciding which skewers I should use :lol:
Ti or dye!
+1 on tune
by sugarkane
Also +1 on the tune dc14
Never heard of one failing either.
Needing 200g worth of skewers is living in the 1990s if you ask me but that IMO :mrgreen:
by kode54
sugarkane wrote:Also +1 on the tune dc14
when the DC14 first came out...i had the carbon lever portion come out of the alloy part. apparently, the glue came undone and slipped out. luckily no accident. i got a replacement from FWB and its been fine ever since.
i've been using the Enve titanium skewers lately. i can get a firm clamp with ease.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
by headwind816
I am fan of Salsa skewers. I find them easy to secure and never had an issue (knock on carbon or material of your choice)
by tsutaoka
I'm a fan of Extralite Aliens3s, but my go to racing skewers are Dura Ace
by barsook77
Solid , dependable, no creaking and stiffen up the rear triangle.
DT RWS AL6/V4 grade 5 titanium skewer. Fantastic.
36 gm front 39 rear.
