It is currently Mon Jan 22, 2018 11:17 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Thu Jun 19, 2014 1:54 pm
Hello everyone, last week when I washing my bike I note this big crack in my rear campagnolo zonda 2013.
2 days before I see that, I had a incident with my jacket. It fall in my rear wheel and get in the brake caliper (not in spokes), immediately locking my wheel. So I'm thinking if this can make my rim crack or is this wheel is not for me. I have approx. 100kg and the roads here in my region isn't exactly good, some section remember me a sectour of paris roubaix, I ask this because I have a historic of parts and frames broken. I previously use another zonda for about 4 years without any trouble. Anybody already see this kind of crack in this wheels?
Said this, in your opinion the crack is cause by my incident, my weight + bad roads or just wheel?
PostPosted: Thu Jun 19, 2014 2:00 pm
Send it back for warranty
PostPosted: Fri Jun 20, 2014 11:22 am
If you are 100kg, then the Zonda should be quite a good choice actually for a relatovely light weight all rounder wheelset.
If the jacket catch involved in that rim crack, how did the jacket end up looking?
I assume you managed to stay upright, which is a good thing.
Talk to your dealer about it, as LionelB mentioned.
PostPosted: Fri Jun 20, 2014 1:39 pm
Yes, I managed to stay upright, just let a long black line on asphalt, so much so that my first reaction was to look at the tire to see if was possible to continue my ride. The jacket survive relatively well with just some stretch lines in sleeve, I think this is because it was folded in my rear pocket.
About warranty, I live in Brazil, bought this wheel in chainreaction, so with the money I will spend to send it back and the time this will take, I think my best option was buy a reposition rim, already I know how to make the substitution and have the correct tools to make this.
But my biggest question is: I could have this trouble again? I make a graphic below to explain what I think happened, but I don't know if its possible.
PostPosted: Fri Jun 20, 2014 1:42 pm
Yikes. That is a big crack. I still doubt that your jacket had anything to do with it, but just the same, I would not 'muddy the waters' in any warranty claim.
PostPosted: Fri Jun 20, 2014 1:59 pm
I was wondering how the cost of a new rim and rebuild would compare to a new wheel. Ribble only look to be selling wheels in pairs, but they do have a rear Fulcrum with Campy freehub that looks similar to a Zonda for $200.
http://www.ribblecycles.co.uk/sp/road-track-bike/wheels-factory-built-wheels-factory-clearance-fulcrum-rear-whl-racing-3-2way-fit/fulcwhcl036
Although I like Campy wheels, this does illustrate the problems of repairing them.
There's sometimes a buggy.
One.
PostPosted: Fri Jun 20, 2014 2:45 pm
rim cost 138 USD, shipping cost 54 USD rebuild cost 0, just my time to do that.
PostPosted: Fri Jun 20, 2014 4:13 pm
1] Don't mention weight or other issues when you bring it in for warranty.
You did nothing abnormal, issue was there out of nowhere/unexpectedly without a known cause.
2] Sending back to UK is expensive but Campagnolo has worldwide service centers. Also in Brazil. Think in this case that will be the better route.
look on the Service pages.
http://www.campagnolo.com/jsp/en/service/index.jsp
Maybe first contact Chainreaction and ask them if they can arrange for you to send it in to the Service centre in Brazil. (You have a legal contract with the shop and not with Campagnolo. The shop has much more obligations to you than Campa. Therefore the shop is the first point you contact when having issues)
3] Although there are people with your weight using Zonda's without problems its not a recommended wheelset for your weight. For your weight and conditions (bad roads) A wheelset with more spokes in it will suit you better.
PostPosted: Thu Jul 03, 2014 2:22 am
Some updates.
My new rim arrived and I dismounted the wheel.
Here are some pics with the weight of the parts.
And suprise!!
The new rim is about 40g heavier then the old one.
PostPosted: Thu Jul 03, 2014 6:39 pm
So you did nothin with warranty? or was it expired?
The 40 gr increase is maybe because its 2way fit rim vs clincher only?
PostPosted: Thu Jul 03, 2014 10:22 pm
No this is the clincher only, 2 way fit is more expensive.
I buy a new rim because I think this is more fast and cause me less trouble.
PostPosted: Fri Jul 04, 2014 10:50 am
Big surprise 2!!
The new rim is heavier, have a much rough finish and is MADE IN CHINA!!
I thought I'd never see this on a campagnolo label.
PostPosted: Fri Jul 04, 2014 11:26 am
wake up people :)
good weight - almost same as fulcrums 1 /shamals
i weight rear at 480g
http://kavitec.blogspot.com/
My NEED FOR SPEED ride:)
https://www.youtube.com/watch?v=8hhlPRud7oM
PostPosted: Mon Jul 31, 2017 2:57 pm
Hi people, I still sufrering of the same problem with this zonda wheelset. The first replacement rim cracked and now the second replacement too, both exactly the same way, so this is third cracked rim. Every time a assembly the wheel with the same spoke tension that I measured before I replace the first rim, even a litle lower to try prevent this problem. What to do now, buy a new zonda c-17, try a fourth rim, buy other wheel model/brand. I realy like campagnolo hubs/bearings, but now I dont know what to do.
PostPosted: Mon Jul 31, 2017 4:34 pm
I think you might have some faulty scales. even if you are 100kg, add to that, rough roads on a wheelset that ways 1.5kg, really, what do you expect.
100kg, how tall are you, 210cm? probably not, so you should loose some weight. it's the best thing you could do for your wheels, cycling and life. i say this as an earnest gesture of goodwill.
There are no new unread posts for this topic. Cracked my Supersix hi mod
tarmackev
10
2457
Tue May 23, 2017 1:22 pm
Calnago View the latest post
There are no new unread posts for this topic. Pacenti SL23 cracked, now what?
DeLuz
11
1063
Tue Oct 17, 2017 10:56 pm
hmai18 View the latest post
There are no new unread posts for this topic. Attachment(s) Cracked Brand New Emonda :-(
Geordiepaul
19
2829
Sat Aug 12, 2017 9:30 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Attachment(s) Cracked Fork or Paint Chip?
BlueberryCake
Tue Dec 12, 2017 7:26 am
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1563
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
Users browsing this forum: Chris3g, dricked, euan, Google [Bot], Google Adsense [Bot], IrrelevantD, LouisN, Miller, TLN, zappafile123 and 51 guests
