It is currently Mon Jan 23, 2017 8:06 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Jun 18, 2014 2:55 am
Hi guys,
couldn't find anything on the search: is it possible to repair a torn 9070 di2 cable? My cable from the left TT handlebar shifter to the junction box got shorn off during transport. It seems the cable doesnt plug into the shifter, but is directly attached.
Any experience and guidance is appreciated.
Best
Nicolas
No longer in the industry
PostPosted: Wed Jun 18, 2014 3:09 am
jever98 wrote:
Hi guys,
Best
Nicolas
I am an engineer. And this should not be an issue if u have a soldering iron.
PostPosted: Wed Jun 18, 2014 3:11 am
It'll be tricky they engineered the e-tube wires to be hard to splice in order to stop people from messing with them.
Sent from my SGH-I337M using Tapatalk
PostPosted: Wed Jun 18, 2014 3:46 am
Not difficult at all. Though admittedly the wires are very thin. Do the soldering under a magnifier and do it quickly.
PostPosted: Wed Jun 18, 2014 4:58 am
Thanks to you all! There are 2 wires in the e-tubes, right?
If I can't get my hand on soldering equipment (am on the road) - is it possible to connect a new cable at the brake?
Best
Nicolas
PostPosted: Wed Jun 18, 2014 7:29 am
I used the more expensive/flexible heat shrink. Have two small pieces to go over the induvidual wires, then use a slightly larger piece to go over the two wires & seal the joint. The new joint will not be anywhere near as flexible as the standard wires, so consider where your bends are when you go to splice things.
I've run 6770 through my p4 without drilling out any holes, made custom length wires and ridden it to the death in rain without issue, so it's very possible, but if not handy with the soldiering iron, have an electrically inclined friend show you the ropes for the first few.
There are no new unread posts for this topic. Scott Addict SL Cable Stops for internal cable routing
kulivontot
Sat Sep 10, 2016 4:33 am
kulivontot View the latest post
There are no new unread posts for this topic. Attachment(s) DA 9070 RD + 30T?
grnrcr
24
1221
Fri Jun 10, 2016 9:15 pm
Ritxis View the latest post
There are no new unread posts for this topic. DA 9070 sleep mode?
Delorre
19
1039
Sun May 29, 2016 12:36 pm
Delorre View the latest post
There are no new unread posts for this topic. Dura Ace 9070 Di2 for Pinarello F8
fh8425
Sat Jun 25, 2016 5:28 am
fr1 View the latest post
There are no new unread posts for this topic. Campy cassette on Di2 9070
coppercook62
11
999
Thu Jun 02, 2016 1:00 pm
micro553 View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], ooo, TheDarkInstall, Yahoo [Bot] and 31 guests
