It is currently Mon Mar 27, 2017 7:37 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Wed Jun 18, 2014 2:13 am
I have had my Carbino Flow for a few thousand miles now, and it is starting to creak, and pop. I lubed with carbon assembly paste, and re-torqued, still noisy. I confirmed this again by switching to another SLR on a different bike. No creak, and piping. Can anything be done about this? Has this been a common thing on saddles with composite rails?
FWIW, I am 150 pounds max.
Thanks
PostPosted: Wed Jun 18, 2014 2:25 am
I had one that creaked, not at clamping area but at the point where carbon rails are connected to the saddle (at the back).
There are two slots at the back where rails enter the saddle, try lubing or gluing this area...
PostPosted: Wed Jun 18, 2014 2:27 am
I had this same problem years ago on a kit carbonio. Try some chain lube in the nose where the rails meet. If you have a circular cradle, make sure all of the interfaces have carbon paste applied even if they are aluminum. Also, if you set back a lot from the clamp, it tends to work its way back, making noise in the process.
PostPosted: Wed Jun 18, 2014 2:53 am
Thanks. It is coming form the nose mostly. I will try a drop or two of lube. Seems likely that that is all that is is
There are no new unread posts for this topic. Selle Italia SLR flow vs an SLR Superflow S (130) - SADDLES
cmcdonnell
Thu Jun 09, 2016 1:56 pm
mrlobber View the latest post
There are no new unread posts for this topic. Selle Italia SLR Kit Carbonio Flow vs S-works Toupe 2013
PrettyA
9
934
Wed Jun 22, 2016 11:55 am
Kayrehn View the latest post
There are no new unread posts for this topic. Attachment(s) Selle Italia C59
leej88
15
2181
Sun Mar 12, 2017 11:50 am
Luca79 View the latest post
There are no new unread posts for this topic. Help Identify this Selle Italia Seat
1flytriguy
Mon Feb 13, 2017 1:30 am
5 8 5 View the latest post
There are no new unread posts for this topic. Selle italia k. Carbonio vs Fizik Arione/Antares
gitsome
11
742
Mon Mar 06, 2017 9:23 am
madik View the latest post
Users browsing this forum: Bing [Bot], brockd15, corky, Google [Bot], merlinxlm, nafaiutb, Yahoo [Bot] and 19 guests
