It is currently Wed Jan 24, 2018 11:03 am
PostPosted: Sun Jun 15, 2014 1:34 am
Dear Friends,
This time I got a 2008 scott addict ltd frame and trying to assemble.
But I don't know Which Ritchey headset fit to the Addict Ltd 2008 frame (Type, Size)
Does anybody here know which Ritchey WCS headset comes on the Addict?
PostPosted: Sun Jun 15, 2014 1:46 am
Ritchey Press-fit 1 1/8"
The WCS, Pro or Superlogic will work
PostPosted: Sun Jun 15, 2014 1:53 am
Is there many kinds of Ritchey Press-fit 1.1/8" as follows
46mm outer
50mm outer
1 1/8" to 1.5" tapered
Which type of headset is correct?
PostPosted: Sun Jun 15, 2014 1:59 am
You want the 1 1/8".
The Addict Is not tapered.
PostPosted: Sun Jun 15, 2014 2:21 am
Yes I want 1 1/8" but i don't know the diameter of headtube is 46mm or 50mm
PostPosted: Sun Jun 15, 2014 8:24 am
You can measure the diameter with a caliber.
http://problemsolversbike.com/files/tech/s.h.i.s.pdf
PostPosted: Sun Jun 15, 2014 8:45 am
41 x 30.15. 45 degrees.
Been through a few sets of the ritchey bearings which became notchy quickly. Replaced with Enduro bearings and no issues to report.
PostPosted: Sun Jun 15, 2014 11:02 am
46mm outer
50mm outer
That's a tapered headset, 1-1/8" at the top and 1-1/2" at the bottom. It won't fit the addict. It would be too big at the bottom.
The Addict fork is 1-1/8" and does not taper.
You need to get a Ritchey 1-1/8" press-fit, 1-1/8" at the top and the bottom.
There are no new unread posts for this topic. Scott addict 2017 headset
Jbarker1975
Sun Sep 10, 2017 6:06 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Addict SL opinions on value
AddictSL58
Wed Aug 09, 2017 6:03 pm
AddictSL58 View the latest post
There are no new unread posts for this topic. Addict Owners...Questions
1spd
Tue Apr 04, 2017 7:35 pm
oreoboreo View the latest post
There are no new unread posts for this topic. I'm looking at buying a Scott Addict
dim
Fri Dec 01, 2017 5:15 am
TonyM View the latest post
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
6958
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
Users browsing this forum: benzebub, Bing [Bot], Google [Bot], jlok, JScycle, Mockenrue, Monkeyfudger, Pijpie, reedplayer, torinb and 19 guests
