It is currently Tue Oct 17, 2017 11:04 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Mon Jun 16, 2014 9:42 pm
if you decide to go with a 24mm spindle, don't bother with adapters, and go for a proper bb like rotor offers. and look at http://www.bbright.net/ when you get a chance.
PostPosted: Mon Jun 16, 2014 9:49 pm
Moderator / Brake Pad Boy
You have lots of options, as you can see below. As for campagnolo, you 'can' use it with Shimano, it will work flawless (I run it for over 3 years now). I would opt for Rotor 3D+ (30mm spindle) in therms of perfect, don't look back, crank. Otherwise THM M3.
More info: http://www.bbright.net/supportingbrands.aspx
Colnago extreme-C Scott Addict SL
PostPosted: Mon Jun 16, 2014 9:53 pm
Thanks, gents....that website is good info. I will look for a 3D+. :beerchug:
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon Jun 16, 2014 10:03 pm
Up selling the CAAD10 for a Cervelo. :)
PostPosted: Mon Jun 16, 2014 10:04 pm
:wink:
Mosaic RS-1
PostPosted: Mon Jun 16, 2014 11:52 pm
i think you're going to be very happy with the r3, until you sell it for a caad.
PostPosted: Tue Jun 17, 2014 12:14 am
Truth. :beerchug:
I give it until spring 2015? :thumbup:
PostPosted: Tue Jun 17, 2014 12:28 am
To piggy-back on the Rotor/BB questions; is it worth using the newer 3D+ on a BSA-equipped frame via the Rotor BB adapter? Any issues with that?
PostPosted: Tue Jun 17, 2014 12:38 pm
Yes, That is maybe even the best solution out there. A very wide bearing stance and trouble and creak free BSA threaded cups. So they are not adapters, but real cups like Dura Ace, just bigger.
PostPosted: Tue Jun 17, 2014 12:47 pm
The best crankset for BBright is a THM Clavicula Road Crankset with a THM BBright bottom bracket.
It is more expensive, but much lighter than the Rotor. You can install it with a SRAM or Rotor bottom bracket, the THM BB is better. I also like the shape of the THM much better, no busting open your ankles on the sharp edges of the Rotor.
PostPosted: Tue Jun 17, 2014 3:54 pm
mjduct wrote:
Campagnolo over torque! Super light and super stiff
You can call Cervelo directly as I have, after one frame replaced and the other sent back to the shop 3 times, Campy is no longer supporting BBright. The BB right Campy cups were manufactured a tad too small.
Campy is not willing to make new ones as not many people are on Campy who ride Cervelo and Cervelo does not offer a Campy build.
I had a BBright frame that lasted a year without any issues, but over time the BB cups will fail and you will notice stciking when you pedal.
To be hones I dont know why there is not a recall on the cups, but I was left with a perfectly good Campy 11 speed crank and decided to go with Power2max and rotor crank.
PostPosted: Thu Jun 19, 2014 2:46 pm
53x12 wrote:
Truth. :beerchug:
i might take the under on that. :D
There are no new unread posts for this topic. Thread together BB for BBRight
morganb
Wed Sep 27, 2017 6:09 pm
stevod View the latest post
There are no new unread posts for this topic. Vumaquad on a pressfit bbright
JLS
Sat Feb 04, 2017 8:27 pm
BMWCARMAN View the latest post
There are no new unread posts for this topic. Recommend a bottom bracket for BBright
stripes
11
1244
Wed Jan 18, 2017 6:10 pm
1415chris View the latest post
There are no new unread posts for this topic. Sram Red BB30 chainset (integral spider) fitted to BBRight....
pavlo
Wed May 17, 2017 12:47 am
pavlo View the latest post
There are no new unread posts for this topic. Attachment(s) THM crankset on a C60
Heavyhitter
7
1150
Tue Dec 06, 2016 3:45 pm
Heavyhitter View the latest post
Users browsing this forum: Bing [Bot], hamd, liam7020 and 35 guests
