Best BBRight Crankset
btompkins0112
by btompkins0112
Hey, y'all. New to this BBRight thing. What's the best crank for an upgrade? Rotor is the obvious choice, but I've heard that 386Evo cranks will fit, which opens a few options.
Sent from my SM-N900V using Tapatalk
1415chris
by 1415chris
If you are looking for 30mm spindle crank, just avoid these in BB30 standard (spindle isn't long enough) and you will be fine. 386evo is OK.
btompkins0112
by btompkins0112
Thanks for the reply.....so 386 is good. I guess I could also get am adapter to run Hollowtech II cranks. Is PF30 long enough?
1415chris
by 1415chris
I am not so sure what you mean by "PF30 long enough".
If you are asking whether it is possible to use HT2 on BBright, yes you can go that way as well, of course, as you mentioned with appropriate adapter and you may need the washers to keep the NDS arm away from the chainstay.
Geoff
by Geoff
The Rotor crank is pretty nice, actually (goofy graphics aside). I like the SRM, too...
coppercook62
by coppercook62
Thm m3
Getter
by Getter
Rotor has a BBright to Shimano adapter.
http://www.excelsports.com/main.asp?pag ... =1&minor=6
Cervelolite
by Cervelolite
I run a DA9000 crank with rotor adapters. Simply the best crank ever
mjduct
by mjduct
Campagnolo over torque! Super light and super stiff
bm0p700f
by bm0p700f
I was about to say Over Torque too.
btompkins0112
by btompkins0112
Can't run Campy.....Shimano group :(
btompkins0112
by btompkins0112
Am I correct in saying that either the Rotor 3D or 3D plus will work with BBRight, but the 3DF is a 24mm spindle that would not work?
Mario Jr.
by Mario Jr.
All Rotor cranks can work. Only a matter of the right bearing kit.
Also, 3DF (Now 3D30) has a 30mm spindle. (Hence the name) 3D+ has the same type spindle whereas the 3D (now 3D24) has a 24mm spindle. (Again, hence the name) 8)
The new 3D+ is nice and quite light. Also the new graphics is much better than before and not slightly goofy imo. :mrgreen:
geedawg
by geedawg
Got my old zipp vumas to work. Still love that crank
