It is currently Fri Jan 19, 2018 1:03 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Rotor 3D+ Help
PostPosted: Sat Jun 14, 2014 2:23 pm
Hi ALL
I hope someone can help me my Rotor Crank extractor ring got cross threaded when removing to replace my Bottom Bracket. now the threads are ruined i cant remove the crank.
Any ideas people as i really need to get this done as the sound of a creaking BB is driving me crazy.
Thanks
 Post subject: Re: Rotor 3D+ Help
PostPosted: Sat Jun 14, 2014 9:46 pm
Can you back-out the appliance? If you can, you may be able to re-cut the threads. If not, you may need to cut the appliance out and pull the crank with a gear puller. You might also pull the other arm out and get it out that way, too.
PostPosted: Tue Jun 17, 2014 9:37 pm
Try using a wooden dowel rod placed on the spindle in the hole where the ring is supposed to go and tapping the end of the spindle until frees itself from the drive side crank arm.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Fri Jun 20, 2014 7:41 pm
If you can get the extractor ring out of the crank, it should be possible to retap the arm (might need to take it to a machinist to fill and recut the aluminum or to make you a slightly larger ring)
As rmerka said, one the ring is out you should be able to tap out the crank with a punch and a mallet.
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2940
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
There are no new unread posts for this topic. Rotor 3D+ change shaft
Erwin
Sun Oct 29, 2017 2:50 pm
dfischer1 View the latest post
There are no new unread posts for this topic. Which Rotor crankset for Power2Max for BB30?
JunkyCollegeBiker18
13
1046
Wed Mar 01, 2017 7:32 pm
jfranci3 View the latest post
There are no new unread posts for this topic. Direct mount 1x chainring for Rotor 3D?
bkw
Sat Jun 03, 2017 2:13 pm
basurper View the latest post
There are no new unread posts for this topic. Quarq Dfour with Rotor QXL rings
TroyG
Fri Jul 28, 2017 6:13 am
TobinHatesYou View the latest post
Users browsing this forum: Baidu [Spider], BigPoser, ghostryder, Imaking20 and 26 guests
