It is currently Fri Jun 23, 2017 4:23 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Sat Jun 14, 2014 4:00 am
I was wondering if anyone is using these bottle cages. They claim 15gr. How well do they hold bottles?
██ MARTINI
PostPosted: Sat Jun 14, 2014 7:36 am
At 60 Euro a piece, I hope they not only hold your bottle, but also keep it refridgerated...
PostPosted: Sat Jun 14, 2014 1:08 pm
I buy 16gram (claimed) Bontrager knockoffs for $11 from Aliexpress. They work just fine, and weigh 15-17 grams. I spray-paint them black, so that adds a tiny bit of weight.
Trek Madone 7.9 58cm 14.9lbs
PostPosted: Sat Jun 14, 2014 1:16 pm
I didn't have the same luck with those.. they really loosen up quickly.. the real ones are much nicer but expensive.
PostPosted: Sun Jun 15, 2014 12:03 am
Just wondering if anyone are using them. Not really interested in knockoffs since I have super record bottle cage at the moment.
██ MARTINI
PostPosted: Sun Jun 15, 2014 2:10 pm
We should be getting those on our next shipment but I worry about something with these. The resemble to previous Sior model or the old New Ultimate....they hold the bottle very well but they are a PITA to put the bottle back or pull it since the band around the bottle is closed (doesn't expand or is cut like the new Sior MIO).....if you have insulated bottles like polar or Camelbak even worst......but lets see when they get in.
www.royalbicycles.com
PostPosted: Sun Jun 15, 2014 2:50 pm
Thanks for the info. Let us know how they are when you receive them.
██ MARTINI
PostPosted: Thu Nov 13, 2014 7:21 pm
Any updates on whether the Leggero is a decent cage?
Oof.
PostPosted: Sat Nov 15, 2014 7:50 pm
I tried them , but returned them because the bottles were rattling alot and i use elite bottles. Every little bump you woud hear it rattle. Don't know if the set I received were a bad batch. Although the weight was good at 15 grams. I think the problem with mine was that they didn't hold enough on the top of the bottle so it would move sideways. Maybe they fixed the problem who knows.
Maybe someone else has had better luck with these.
██ MARTINI
PostPosted: Sat Nov 15, 2014 8:43 pm
I've had one of these cages for about 6 months. At first I was worried when the bottle was rattling around in the cage a little, fearing it was just not held properly and would fall out often. It turns out it retains the bottle fine. It's a loose-fitting cage but it has a tight-fitting exit path. I've been using Purist bottles all season and I don't really notice much rattling sound. Maybe a bottle made of stiffer plastic would make more noise.
PostPosted: Sun Nov 16, 2014 3:44 am
Exactly they are loose fitting. The bottles were always rattling and it was driving me mad. At first I thought that something on my bike was creaking. If they were a little bit tighter there would not be any problems. But maybe they fixed the problem who knows.
██ MARTINI
PostPosted: Sun Nov 16, 2014 5:45 am
Keep in mind the really flexible cages can put extra stress on the threaded rivets in your frame and wiggle them loose. I've gone away from the BTP cages I used to use and instead switched to the Arundel Mandible after having a few bottle cage rivet failures.
Light. Strong. Cheap. Pick one.
PostPosted: Sun Nov 16, 2014 6:37 am
I understand, but these cages are not flexible. very sturdy and light. Just the bottles are not tight enough in the ones I had.
██ MARTINI
deleted the quote. this is a reply.
There are no new unread posts for this topic. Attachment(s) anyone use this aero bottle cage?
addictR1
15
1971
Mon Feb 20, 2017 7:05 pm
addictR1 View the latest post
There are no new unread posts for this topic. Lightweight Bottle Cage - Tune??
nibby
16
1371
Fri Aug 05, 2016 9:27 pm
jrmynthn View the latest post
There are no new unread posts for this topic. Bottle cage (I hope with pics)
Timmy269
11
676
Wed May 03, 2017 12:08 pm
Timmy269 View the latest post
There are no new unread posts for this topic. Any experience with HanniDesign 6.5g bottle cage?
synthesis
Fri Jul 01, 2016 10:55 pm
synthesis View the latest post
There are no new unread posts for this topic. Supersix - what chain keeper and what cage/bottle ?
island
Mon Apr 03, 2017 12:10 am
froze View the latest post
Users browsing this forum: Bluechip, bomber, indywagon and 30 guests
