It is currently Fri Jan 19, 2018 1:03 am
PostPosted: Fri Jun 13, 2014 7:17 am
I have a Rotor 3D+ crankset on one bike and just got the Cannondale Hollowgram SiSL2 for another. The difference in Q-factor is 6mm. I have two sets of Speedplay Zero Ti pedals.
My question is: Could I safely use 3mm of pedal washers on each Zero Ti pedal on the Hollowgram crank? Anyone have any advice/experience? I know I could just use the 3mm longer spindles on the Zero Stainless Steel pedals, but would prefer not to if I don't have to.
I also measured the length of the threaded portion of the pedals and it came out to 13mm.
2016 Cannondale SuperSix EVO Hi-MOD IN PROGRESS
2014 Cannondale SuperSix EVO Hi-MOD, 5.79kg RETIRED
2014 Cannondale CAAD10, 6.83kg RETIRED
PostPosted: Fri Jun 13, 2014 12:10 pm
Would it not be easier to move the cleat sideways 3mm?
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
PostPosted: Fri Jun 13, 2014 12:41 pm
Or buy some longer Ti spindles?
PostPosted: Fri Jun 13, 2014 4:21 pm
Moving the cleat doesn't solve the q-factor discrepancy when moving from bike to bike.
I was trying to avoid spending further money but longer ti spindles might have to be the solution if no one chimes in and says they've seen 3mm of washers be safely used. Any recommendations anyone?
PostPosted: Fri Jun 13, 2014 5:19 pm
I wouldn't use washers in that area. The stress factor of the Ti-spindle has got to be very high there and washers will only give you less contact to the arm with threads. Go longer spindles and you don't have to think about safety issues. I have longer ti-spindles and only weigh 130lbs but I think they have a limit of 180lbs direct from Speedplay, you might want to check on that.
PostPosted: Sat Jun 14, 2014 2:00 am
Did you get longer Ti spindles from Speedplay? My understanding is that they only provide different length spindles in stainless steal and custom Ti lengths are only available as third party.
PostPosted: Sun Jun 15, 2014 6:33 am
http://www.titaniumspindles.com/
I would contact them. With the stronger titanium that they have, they can probably help you out. Calling them works better. Search around here and you will find more about them. I have purchased several spindles from them in the past. Never had an issue with product or customer support.
PostPosted: Sun Jun 15, 2014 12:42 pm
I bought mine second hand from somebody on a forum moving to mtn bikes. They were barley used and they said they ordered them direct from a speedplay dealer with the longer axels. It doesn't matter where you get the longer axels as they will be to the same spec and work fine. Actually the needle bearings didn't last as long as the axels and I have since replaced the zero-ti to the zero-ss body on the ti axels and it is a much stronger combo.
There are no new unread posts for this topic. Fine to use Look's Q-Factor washers on Speedplays?
Shrike
Tue Feb 28, 2017 5:40 pm
Shrike View the latest post
There are no new unread posts for this topic. Look pedal washers and Keo Blade 2
liam7020
Wed Jan 25, 2017 1:03 am
liam7020 View the latest post
There are no new unread posts for this topic. Acros the clamp thin metal washers
Alexandrumarian
Sat Sep 09, 2017 1:29 am
Alexandrumarian View the latest post
There are no new unread posts for this topic. Attachment(s) new 2018 Hollowgram SISL2
eliflap-scalpel
Thu Jan 18, 2018 7:17 am
eliflap-scalpel View the latest post
There are no new unread posts for this topic. Attachment(s) New SISL2 crank arms - Is this a defect or normal?
glowder
Wed Dec 06, 2017 11:55 pm
Jenmoss View the latest post
Users browsing this forum: Baidu [Spider], BigPoser, Bing [Bot], ghostryder, Imaking20 and 25 guests
