Super Record EPS RD Question
mpower
by mpower
Do you think a 11/32T cassette will work with it?
Permon
by Permon
As far as I know, 29t cog is the max for Campy RDs.
bikerjulio
by bikerjulio
There's a 2-part answer to the question.
One is the issue of cage length and the amount of chain to be taken up in going from big-big to small-small. The maximum safe number for a short cage RD is 30 teeth total. So the 11-32 has an 21T range and a 39-53 crankset has 14T for a total of 35T or well in excess of what the RD can handle. With a compact on front, it's worse of course. So, it requires a medium cage RD and It does not look like such a thing is available in EPS.
Second is the issue of upper pulley clearance from the big sprocket. Campy do make a 12-30 in 10-speed (which I have), and there is sufficient clearance. And here I'm assuming that the basic RD geometry is the same, which I believe to be so. So, it's possible there may be clearance, but it's going to come down to individual frame and hanger differences.
This is a long way of saying that I don't believe it's possible to do with standard EPS. Wider range gearing is possible with Athena mechanical which does offer a medium cage RD, so just maybe a cage swap is possible, I don't know.
There's sometimes a buggy.
One.
Causidicus
by Causidicus
bikerjulio
by bikerjulio
Causidicus wrote:Could put the long cage Athena 11 triple cage on the EPS RD. Still might not clear a 32 without a longer hanger.
isn't that what I said??
One.
mjduct
by mjduct
What is your front end, if you are running a single ring you can make it work :)
Causidicus
by Causidicus
mikey168
by mikey168
I have tried this (11-32 sram force with SR EPS rear mech) on my trainer...
The results are just not consistently reliable enough (only successfully half the time), plus the stress on the chain would be too much...
If you nurse it VERY CAREFULLY and (I mean very) it will shift on the big-big combo. However when shifting out on the road, it's just not practical.... Don't risk it, it's not worth the trouble
Hope this helps
sugarkane
by sugarkane
Shoot me an email. I have a way that should work!
