Consensus on alternative Campy cranksets
by Nefarious86
Ok then put a .75mm spacer behind the campy pedals and adjust your cleats to match. Simples.
Using Tapatalk
alexaqui
by alexaqui
Thank you for the responses. What prompted this is the opportunity to buy a reconditioned Rotor from SRM. With the cost of a new cranks plus the proceeds from sales from the old stuff, the cost differential is not tremendous. It seems like shifting is a non-issue for the Rotor. There seem to be a fair bit of responses around different forum related to Rotors cracking.
Given the choice between the Rotor, THM M3 (6-8 week wait), or another Campy crank, what would you recommend? The THM and Campy are going to cost around the same. The rotor is a fair bit less expensive.
NiFTY
by NiFTY
Every mm of q factor is worth 40W. Get real mate. Look at it on a ruler.
Lewis
by Lewis
This thread needs some pics of your set ups too lads!
2012 Canyon Ultimate AL 8.0
