Parlee Z5 seatpost, aluminum vs carbon
bicicleta
by bicicleta
Just bought my first new road bike :D , after debating between a 2013 Cervelo R3 a Cannondale EVO 6 and a Specialized Tarmac and
hoping to spend no more than 2500.00 US, I stumbled upon a Parlee Z5 on clearance and I couldn't walk away from it. I got it with Mavic
wheels and the old Force groupset and I just swapped new Force 22 and Reynolds tubeless wheels.
The only thing I think I will need to change now is a setback seatpost, I always had bikes with 27.2mm carbon seatpost and I have no
experience with a 31.6 seatpost and I wonder if I go aluminum will the ride quality suffer much?
I looked up a post with Parlee Z5 and seatpost suggestions and it wasn't very helpful to me because I'm not looking to spending 500.00 USD
on a seatpost, I just need something easy to adjust and reliable, not too heavy would be a bonus, looking to spend no more than 300.00 USD.
Any help and ideas appreciated.
mattyNor
by mattyNor
Get Thomson don't make this more complicated than it needs to be ;)
Sent from my SGH-I337M using Tapatalk
bicicleta
by bicicleta
mattyNor wrote:Get Thomson don't make this more complicated than it needs to be ;)
Not so much in love with their setback design, but a very very good seatpost indeed, if I can find it locally I'd have to see how it looks on the bike.
Thanks for the suggestion.
NiFTY
by NiFTY
Just get a carbon post on ebay. Ritchey superlogic can be found for about $150, buy a Ti bolt for the clamp and cut the unwanted length and you'll have a 150g setback seatpost for under 200 shipped
kaaos
by kaaos
why don't you get a same 3T seatpost but with setback... 3T Dorico Team will be a perfect match for your frame
kaaos
by kaaos
:D
kode54
by kode54
maybe a Syntace carbon set back P6(?) has some comfort built in.
i use an Enve 31.6 set back on my Z5.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
AndreLM
by AndreLM
Nice bike. Why not a Syntace P6 Carbon Hiflex? In your budget, will give you some comfort, and looks good. It is kinda heavy, though...
OrPe
by OrPe
had good luck with easton's EC90 on a parlee Z4.
you can find these shipped for less than $150 (on the bay').
Oren
veganeric
by veganeric
+1 to NiFTY's suggestion.
bicicleta
by bicicleta
Thanks all for your suggestions. I will see what I can get on ebay.
Right now I'm a bit lost when it comes to buying stuff online because I just moved to Canada (Surrey BC) and I have
not the slightest clue which companies ship here, import duties, etc...
The only thing I'm sure of is most everything is MORE expensive in here :evil:
kode54
by kode54
bicicleta wrote:Thanks all for your suggestions. I will see what I can get on ebay.
i have an Enve 31.6 set back seat post on my Z5. i've had a Syntace P6 on my Storck, but prefer the Enve post. goes well with the Z5 SLi.
rijndael
by rijndael
Your seat looks pretty far forward on a 0 offset post, are you sure you want to go with a setback post?
bicicleta
by bicicleta
rijndael wrote:Your seat looks pretty far forward on a 0 offset post, are you sure you want to go with a setback post?
The seat is like that because I had just put the bike together, that's how it came from the bike shop. For me to even get 50mm setback
I'd have to push the saddle all the way back to the limit of the rails. I have long femurs and I have always felt better using set back seatposts
on bikes with 73' angle seat tubes.
I will meet a guy from Craigslist that has a brand new, never installed ENVE post for 200.00 CND.
Are there any counterfeit ENVE posts floating around, anything I should be aware of? :shock:
Thanks for all the help and suggestions, I really appreciate this forum :beerchug:
