It is currently Mon Jan 22, 2018 4:46 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon Jun 16, 2014 8:53 pm
We're saying the same thing. I'm just pointing out that many hub's "Campy compatible" actually required moving spacers.
PostPosted: Mon Jun 16, 2014 9:48 pm
JackDaniels wrote:
I was hoping to run some of my shimano 10 speed race wheels with a 11 speed super record bike so I picked up one of these. But I could not get it to work.
With no spacer the hub contacts the spokes, with the smallest spacer there is not enough hub to fully engage the 11t sprocket.
Maybe it could work with other wheels.
Can you elaborate? when you say the hub contacted the spokes, you mean the cassette contacted the spokes right? Is it the case that the largest sprocket is indeed offset towards the spokes? Any chance of a few close up pics of the cassette?
Ti or dye!
PostPosted: Mon Jun 16, 2014 10:03 pm
The extra cog is essentially bolted onto the largest cog of the original (105?) cassette.
(basically like the Shimano 12/14 speed patent)
PostPosted: Mon Jun 16, 2014 11:08 pm
That makes sense.
So... if you have a spoke clearance issue you might be able to space the freehub over a little... maybe a mm or so... by putting spacers on the axle. This will depend on the hub also. You might also want to get a Campy axle and spacers for your hub if available, which would allow you to space closer to the dropout. I wouldn't advise any of this unless you understand what you are doing.
If you can obtain a Campy freehub kit for your wheel, that will be your best bet... and of course you'd need to use Campy cassettes in that case. A redish will be needed for most wheels.
formerly rruff...
PostPosted: Mon Jun 16, 2014 11:36 pm
WMW wrote:
That makes sense.
There's so much wrong with this, it's hard to know where to start.
There's this
which is completely meaningless.
and this
which is just completely wrong.
I'd suggest to all reading this to read my earlier posts, and ask if there is something that I have not explained clearly.
There's sometimes a buggy.
One.
PostPosted: Tue Jun 17, 2014 2:34 am
Yeah sorry I meant the back of the cassette contacted the spokes (Real Design wheels). I'm not going to reinstall the cassette, but I don't get the point as I understand it campy and shimano 11 speed drive trains are compatible, so shouldn't a shimano 11 speed cassette work on an 11 speed campy bike without any special conversion parts?
PostPosted: Tue Jun 17, 2014 4:23 am
kode54 wrote:
what wheels did you try them with? i have a 10spd Lightweight Gen III. was hoping that i can get something to work for 11spd Shimano set up.
Just buy the 11 speed DT240 freehub, swap out the 10 speed freehub, bang on an 11 speed cassette and you are done.
PostPosted: Tue Jun 17, 2014 8:02 am
Thanks for that. Well looking at the picture the carrier seems to be machined so the it sits further inboard when you slide it on the free hub, so I guess they just add another sprocket amongst the singular ones and change the spacers? Not sure exactley what they are doing to make this work, how are they changing the spacers in the carrier? Removing the rivets, changing the spacers then re-riveting? Are they machining the sprockets thinner at all? So many questions! But I guess you are just governed by how much space you have between the last sprocket and the spokes on your desired wheel? Wouldn't it be a good idea if we knew the space required? Like the minimum distance required from your current outer sprocket to the spokes, say 5mm for arguments sake, to allow you to run the Accelerator cassette? Yeah Campag and Shimano 11 should be nigh on the same.
Ti or dye!
PostPosted: Wed Jun 18, 2014 12:32 am
You have a 10spd S rear wheel. You are trying to put 11spd gears on it, and 11spd S cassettes are not compatible with 10spd S freehubs. The gear cluster is 2.85mm wider so you can have clearance issues.
formerly rruff...
PostPosted: Wed Jun 18, 2014 8:16 pm
Ok, I spoke too soon on this. I gave it another try, and using two of the super thin washers included with the cassette I was able to get it to work.
So now I am running a 10 speed shimano wheel on an 11 speed campy bike. I may want to hold off on calling this a complete success until I get a longer test ride, but the cassette is not rubbing, the small cog has plenty of bite on the freehub and it seems to shift well.
I should have read the instructions more thoroughly but I was trying to throw this on an hour before a race.
edit: of course ymmv
PostPosted: Thu Jun 19, 2014 12:07 am
So this MIGHT work as I envisaged (hoped) ?
So to sum it up - Shimano 10sp hub and 11sp WM 11 sp Acc cassette = WORKS ? (tbc) :unbelievable:
Whether it is Campy or Shimano 11sp system is irrelevant
PostPosted: Sun Jun 22, 2014 12:59 am
I raced with this today and it worked fine. It might be worth asking wheels if they will do a return if it doesn't work on your wheel.
PostPosted: Sun Jun 22, 2014 10:09 am
I'm thinking wait for Shimano to launch 105 11 speed, those cassettes will have alloy carriers and get your local machine shop to remove material from the lowest cluster like the Accelerator, as long as you have enough clearence at the spokes, BANG the cassette will be Shimano and Campagnolo compatible 8)
Ti or dye!
PostPosted: Mon Jun 23, 2014 10:00 am
@ BeeBee30
The most likely scenario. I'll do my best to just be happy with what I have .... :?
PostPosted: Tue Jun 24, 2014 3:44 pm
Why not use the Ultegra cassettes that are already available?
formerly rruff...
There are no new unread posts for this topic. Wheels Manufacturing hanger or original Cervelo?
Shrike
Thu Jun 01, 2017 11:14 pm
totalcompactroad View the latest post
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
2037
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. 9-32t cassette with Di2 xtr
Plopplopdougal81
Tue Nov 28, 2017 10:58 am
Jengaback View the latest post
There are no new unread posts for this topic. Cassette Durability
JScycle
34
3623
Mon May 29, 2017 8:43 pm
tarmackev View the latest post
There are no new unread posts for this topic. Anyone got a 36t cassette and can help me with the diameter of that cog?
alcatraz
Thu Jul 06, 2017 11:22 am
Kurets View the latest post
Users browsing this forum: Bing [Bot], Calvaroz, coriordan, corky, Kaboom, lovemyway, MagicShite, MattMax and 54 guests
