It is currently Mon Jan 22, 2018 1:49 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sun Jun 08, 2014 8:50 pm
Well the title says it all, I just sent my saddle back to Italy to be repaired( great CS so far by Fizik BTW)
I've got a feeling that my Easton EC90 seatpost might be part of the culprit, (slightly narrower than the rails, might have pulled one out of the epoxy bonding it to the shell) do you guys have any other 0-offset posts that work well with the braided carbon rails? I'd like to keep the weight under 200 grams, this would be for a 27.2 diameter.
Thanks!
PostPosted: Mon Jun 09, 2014 1:59 am
Enve and Bontrager do 27.2mm posts with adapters for saddles with carbon rails. I use both and no issues with my San Marco Regale Carbon saddles
Ozrider - Western Australia
PostPosted: Mon Jun 09, 2014 2:11 am
Thomson make zero offset posts in 27.2.
Sent from my iPad using Tapatalk HD
PostPosted: Mon Jun 09, 2014 9:23 am
deda superlegerro is about 185g and 12mm offset, works fine with braided carbon because it clamps top and bottom.
PostPosted: Mon Jun 09, 2014 5:59 pm
I've been looking at this a 27.2 in 250mm length would work on my bike (I'm short) and would only weight about 150 grams...
Lighter, stiffer, and better functioning? Sounds like a winner!
PostPosted: Tue Jun 10, 2014 1:19 am
Focus on comfort > Syntace P6 Hiflex
http://www.syntaceusa.com/index.cfm?pid=3&pk=2033
Focus on lowweight > Smud carbon seatpost
http://smud-carbon.eu/seatpost.html
Dunno how old your Easton is but there was a recall some time ago.
http://bgindy.com/articles/easton-ec90- ... pg1299.htm
PostPosted: Tue Jun 10, 2014 1:51 am
KCNC alloy :D, cut-down<150g :D :D
Less is more.
 Post subject:
PostPosted: Tue Jun 10, 2014 3:50 am
PostPosted: Tue Jun 10, 2014 5:04 am
I happen to have just mounted a Fizik Aliante with oval carbon rails to a Thomson zero setback post (going on a NOS Merckx Team SC) and initial fit is perfect. Thomson posts are hard to beat.
PostPosted: Sat Jun 14, 2014 1:47 am
Thanks lugan probably going that route... Performance has triple points this weekend :)
PostPosted: Sun Jun 15, 2014 2:13 pm
On the KCNC I would recommend their new Carbon rail support kit......
www.royalbicycles.com
PostPosted: Sun Jun 15, 2014 2:20 pm
I've got Pro Vibe UD Carbon 0mm offset seatpost which can hold oval rails see here). Unfortunately, it's pretty heavy with 195g and may be not good for me (I consider selling it).
There are no new unread posts for this topic. seatpost for bontrager 7x10 carbon rails
hoojammyflip
Fri Feb 17, 2017 4:59 am
nickf View the latest post
There are no new unread posts for this topic. Berk list reviews/opinions & round vs oval rails
Lightweenie
Mon Aug 07, 2017 8:52 am
Lightweenie View the latest post
There are no new unread posts for this topic. Darimo Zero Offset 25.4mm seatpost
mike001100
Fri Nov 10, 2017 10:29 pm
mike001100 View the latest post
There are no new unread posts for this topic. SeatPost for Oversized Rails
TarugoKing
Mon Apr 17, 2017 4:41 pm
TarugoKing View the latest post
There are no new unread posts for this topic. Ok to use carbon rails?
addictR1
9
849
Fri Nov 10, 2017 5:15 pm
Butcher View the latest post
Users browsing this forum: HammerTime2, joe1234, nickf, Rioken, Tohan and 39 guests
