Giant TCR SL Headset for 1/18 to 1-1/2 fork
weeracerweenie
by weeracerweenie
I was given a TCR SL a few weeks ago, made it a frame for testing bits on. What i decided i would do was the run discs on, just for un, so i can swap out wheelsets and go ride cross, but its main use will be for the road. anyhow i ordered a Tapered 1-1/8 to 1-1/2 tapered fork, which is between countries currently, but the stupid Giant overdrive is made for 1-1/8 to 1-1/4 tapered forks. I was led astray by being told at the LBS that it ran a standard upper bearing and then on the stock fork it ran a chunkier lower bearing, therefore it should run a normal 1-1/2 fork and bearing happily. So sure enough in confidence i ordered the headset from them and lo and behold the thing is not even close to fitting the 1-1/2 bearing in the bottom... So heres my question...
1) Do i Search in vain for a bearing to run the 47mm OD and 1-1/2 ID
2) Chuck the fork to a machinst and ask them to turn the lower crown to 1-1/4 to run a giant headset (about 3mm per side would be taken off)
3) Spin up a couple brass bushings to use as a lower bearing instead...
Im really annoyed the guy at the bike shop that sells giant assured me it would work out, and now its not an easy bolt together thing.
Any opinions?
I guess there's worse hobbies than making a bike light? Right?
mattyNor
by mattyNor
Isn't the overdrive 1 1/4 upper 1 1/2 lower? If anyone makes any sort of reducer bearing it'll be Chris king.
Sent from my SGH-I337M using Tapatalk
weeracerweenie
by weeracerweenie
The fork that's come out of it is 1-1/8 upper 1-1/4 lower. It's 2011 model SL TCR.
Mr.Gib
by Mr.Gib
If the fork is indeed 1 1/8 to 1 1/4 than the fork is from 2008 or 2009 (can't quite remember when they switched.)
If the frame is indeed 2011 then I would just get the correct fork from Giant.
FYI if the frame is also 2008/2009 than there is a free replacement for the headset. The stock item could not be adjusted properly - it would tighten on its own.
Riding cross on a TCR SL???. Good luck with that cause you'll be doing it on 23 mm or maybe 25 mm tires.
mattyNor
by mattyNor
Right I don't know what is was thinking :P
weeracerweenie
by weeracerweenie
Well the fork I had brought was a cross fork and had the room for a big front tyre, the rear will squeeze a 25. Hmmmm
weeracerweenie
by weeracerweenie
So current option is to ditch the aftermarket fork I brought, buy a standard 1-1/8 fork and headset and run one of these shims which take the headset lower bearing from a 1-1/4 to a 1-1/8 lower OD
weeracerweenie
by weeracerweenie
Oswald
by Oswald
Your best option would be to sell/trade it for a proper cross frame...
Mr.Gib
by Mr.Gib
Yeah if this is going to see any off road use I'd say fuggetaboutit. The rear triangle on the TCR SL is very tight. A 25 mm slick will barely clear the brake bridge and is equally tight behind the BB. Space behind the seat tube isn't much better. Sorry, just not going to work.
Now set it up for road use and you have yourself a real weapon.
weeracerweenie
by weeracerweenie
By off road I mean gravel roads around where we holiday, not proper cross racing. Should have clarified.
Fork and original headset is sold, now trying to find a fork that is to my liking
Mr.Gib
by Mr.Gib
Sorry but you will have the same problem. 25 mm tires on gravel won't be fun.
Oswald
by Oswald
25mm is doable for the occasional gravel section. But there is a big chance of getting a flat tire or falling on your face. I would go for at least a 28mm tire. And that won't fit the TCR.
weeracerweenie
by weeracerweenie
I'm not talking 80km at a time, just splashes to liven up rides and all that. If it doesn't fit I'll run a 23. No big deal.
weeracerweenie
by weeracerweenie
Anyone know of a 1-1/8 non tapered 700c road fork that's not mega dollars?
