Installing BB30 BB with SRAM Red Exogram
drainyoo
by drainyoo
I have an FSA BB30 bottom bracket that comes with a wave washer, and I'm going to be running it with an SRAM Red Exogram crank. Since the crank has a preloader built in, do I still need to use the wave washer?
Zoro
by Zoro
I have this setup on a FELT DA2 and we do use the wave washers. I think it helps keep the cranks in place.
Beancouter
by Beancouter
I don't use the wave washers in mine. Instructions not terribly clear, but that's how I read then!
drainyoo
by drainyoo
Zoro wrote:I have this setup on a FELT DA2 and we do use the wave washers. I think it helps keep the cranks in place.
I guess I'll try it with the washer. It goes on the drive side, right?
grover
by grover
If the non drive side has the threaded preload assembly then you should not use a wavy washer.
JasperGr
by JasperGr
Sorry to kick this topic. I have also a exogram crank and i'm wondering if you need to thighting the bolt till there is no space between the BB and crank or just thight it to 48 Nm?
Rick
by Rick
Just tighten it to the recommended torque.
Take out any extra play with the preload nut and tighten the set screw.
Do not use any wave washers.
upside
by upside
Yup... Ditto, no use of wave washer.
JasperGr
by JasperGr
Oke but which is the preload nut because I only have 1 bolt 8mm and a 10mm ring which is needed tot remove it.
I have a gxp version btw
JasperGr
by JasperGr
goodboyr
by goodboyr
The title says bb30.......
bikerjulio
by bikerjulio
GXP and BB30 are quite different systems. :shock:
There's sometimes a buggy.
One.
JasperGr
by JasperGr
Yhea i know sorry.
