It is currently Sun Jun 25, 2017 3:23 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sat Jun 07, 2014 1:28 pm
Hey all...I'm building up a new ride featuring an Ultegra direct mount brake. The front setup really easily, but the rear is proving to be super tricky. For some reason the brake appears to be off center. I cannot get the arm on the drive side of the bike to open far enough. It doesn't seem to be a spring tension issue. It appears to be the end of it's range of motion. It's so off center that the brake moves the wheel over when the brake is engaged. Any ideas?
PostPosted: Sat Jun 07, 2014 1:55 pm
Housing too short?
Rear housing needs to be just right.
Other than that it's the normal centering procedure for which I use a slim wrench and watch the wheel for any movement as I apply the brake.
There's sometimes a buggy.
One.
PostPosted: Sat Jun 07, 2014 2:29 pm
Ahhhh so a cone wrench near the mounting bolts actually does something? couldn't figure that out. I'll play with it.
PostPosted: Sat Jun 07, 2014 3:31 pm
And I don't even have the cable hooked up yet. I just mount the brake and already have issues touching the rim without any cable tension at all.
PostPosted: Sun Jun 08, 2014 2:03 pm
Although my reply was not completely wrong, I was not understanding "direct mount" at first.
On the Universal Cycles site there is this customer comment which may assist:
Quote:
Did not come with install instructions and i tried to find em online but couldn't (that was until after i finished installing em that i found em on shimanos dealer manual website.)
Unfortunately depending on the bike you will be using em on more then likely you will need to re-do the rear cable housing and possibly the rear cable. Nothing a trip to the LBS couldn't cure but it was added install time.
Warning: Setting up the rear brake on a Madone 5-6-7 series with direct mount is a PITA. Centering em is much easier with these then the bontrager but the cable routing on the rear caliper arm is a nightmare. Only thing ive yet to figure out is why the rear lever requires slightly more force then the front. Otherwise they feel incredible.
One.
There are no new unread posts for this topic. Why no love for direct mount rim brake?
[ Go to page: 1 2 3 4 5 ]
ichobi
73
5959
Mon Apr 24, 2017 4:20 pm
MikeD View the latest post
There are no new unread posts for this topic. Chainstay direct mount brake experiences?
njyeti
18
1697
Wed Sep 21, 2016 1:12 pm
njyeti View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo compatible Direct Mount Bottom Bracket Brake Suggestions
J.v.S.
Thu Mar 09, 2017 10:01 pm
J.v.S. View the latest post
There are no new unread posts for this topic. Direct mount 1x chainring for Rotor 3D?
bkw
Sat Jun 03, 2017 2:13 pm
basurper View the latest post
There are no new unread posts for this topic. ee brakes direct mount - spare parts?
micky
Fri Apr 07, 2017 7:58 pm
kode54 View the latest post
Users browsing this forum: alcatraz, Baidu [Spider], lovemyway, nemeseri, possibleweenie, sungod, willmac, Yahoo [Bot] and 39 guests
