Shimano 6800 chain set compatible with 6700 group?
alastairb
by alastairb
I'm hoping for a bit of technical advice please. I want to run an 11 speed Ultegra 6800 chain set with the rest of an Ultegra 10 speed group and would like to find out if anybody is running this combination and if it's all working ok?
I can't really see why it wouldn't work - the chain rings are the same distance apart and the roller width of the chain is the same for both speeds - but it's a lot of cash to lay out to find it's an issue.
Any help much appreciated.
dmoneysworks
by dmoneysworks
yes but it's recommended to an run a 11 speed chain as well. This is already well documented and used by many people I know.
alastairb
by alastairb
thanks dmoneysworks. I thought chain was usually matched to the cassette (which will be 10 speed) not to the chain set?
dmoneysworks
by dmoneysworks
from memory I read the article on velonews - I'll try find it again. FOUND IT - http://tinyurl.com/lh3yaka :thumbup:
Antoine
by Antoine
I just rode 2 mountainous cyclosportives (170 kms/3200 + and 140 kms / 2700 +) with a 6800 crank and a 7800 group :
6800 crank 11s and the rest 7800 10s including the chain.
I just changed the crank because I needed a compact and it worked perfectly (in fact better because my 7800 chainrings have 17000 kms).
the 11s speed chain is narrower so I don"t know if it would work with a 10s cassette.
rainerhq
by rainerhq
What about vice versa: 6700 crank and all other stuff 6800 (6870)?
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
btompkins0112
by btompkins0112
Should be fine as well.....I have run 11s on a 10s crank without an appreciable difference in performance. That being said I rarely exit the big ring so I can't speak for the shifting too much, but when I did shift it worked.
efeballi
by efeballi
The internal width of an 11s chain is the same as 10s, and the external width is a bit less(0.1 mm if memory serves me right). So no issues with 11s chain meshing with the 10s cassette and rings. The ring spacing is less on Shimano 11s cranks, so 11s chain is ideal. However I don't think it will work that bad with a 10s chain.
I remember someone testing a DA 9000 chain on an otherwise 7900 group and mentioning an improvement in shifting.
SHUT UP LEGS
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
alastairb
by alastairb
Thanks all; sounds like it should be fine.
