It is currently Fri Jan 19, 2018 4:57 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Sat May 31, 2014 3:03 am
The new di2 for mtb has sequential shifting - does this mean it's coming for Road?
This could be just a firmware upgrade or use the MTB front junction box - they say it's pretty programmable? And MTB is available in 2x11
Maybe you just need that LCD display?
PostPosted: Sat May 31, 2014 3:42 am
The mtb/xtr di2 looks pretty wicked, I must agree. What I'd like to know is if the rear d will work with the di2/hydro road shifter. That would be awesome on a cx/gravel rig. Sequential shifting is a really great addition too. Particularly if it manages to happen as transparently as the road di2 shifts now. An electric clutch d on my cx bike is what I've been waiting for! Alas...its probably gonna cost A LOT.
Sent from my SGH-T999 using Tapatalk
PostPosted: Sat May 31, 2014 3:47 am
What is meant by Sequential? Because my road DI2 can change either single or multiple gears already.
2013 Giant TCR Advanced SL 0, 6.92kg
2013 Giant Defy Composite 2 M, 8.5kg - Wife's
Azzurro Torino 8.55g
Fuji 650 10.8kg
Miele Lupa Triple Tandem 38,89kg
PostPosted: Sat May 31, 2014 3:52 am
Sequential means that the brain will decide when to switch the front to get a sequential progression of gear ratios - just press the button to tell the system you want more or less gear and it will figure out the next best combination of front and back to give you that.
PostPosted: Sat May 31, 2014 4:05 am
Lol. Yep just had a quick read on Bike Rumour. Sounds cool.
Fuji 650 10.8kg
PostPosted: Sat May 31, 2014 4:35 am
According to the press release this is all done in Software. What's to preclude someone from using the MTB firmware to run the Road system. Just update your front Junction box and away you go.
PostPosted: Sat May 31, 2014 4:49 am
The display unit functions as Junction A and has three ports - you should be able to plug this into the Road system and get sequential
PostPosted: Sat May 31, 2014 6:06 am
Could mean the end of shifting with your left hand/lever. Which would make the left brifter quite light.
PostPosted: Sat May 31, 2014 10:36 am
Shimano Di2 Sequential Transmission - Fairwheel Bikes (7970 in 2010)
https://www.youtube.com/watch?v=eq_BgmJ ... detailpage
PostPosted: Sat May 31, 2014 10:47 am
Per the display, some guys modified their Ui2 with Alfine Di2 Digital Gear Display SC-705
http://nk.hateblo.jp/entry/2013/02/01/162251
http://handsonbike.blogspot.hk/2013/04/ ... e-di2.html
PostPosted: Sat May 31, 2014 4:07 pm
Hmm, what if you want to shift the front derailleur and keep the rear where it is? I can't imagine pushing button 10 times from lowest gear to higher I need at that moment (those situations happen)
PostPosted: Sat May 31, 2014 5:32 pm
Read the Di2 MTB write-ups apparently you can override the Sequential Program on Demand
PostPosted: Sat May 31, 2014 5:44 pm
Should road system be designed like this?
(In XTR Di2)A front shifter is available, and the whole system can be set into “manual mode,” allowing it to function just like a normal drivetrain. But Synchronized Shift is designed to be used with just a single shifter. The system will decide when to shift the front derailleur, moving across the drivetrains’ entire range. The point at which it shifts the front derailleur will change depending on whether the system is being upshifted or downshifted, and can be manually set as well.
http://velonews.competitor.com/2014/05/ ... xtr_330061
PostPosted: Sat May 31, 2014 7:57 pm
http://youtu.be/lZGuwhSLcJU
Am I wrong but does the efficiency at 1:!0 in the video look wrong....should stay in the 26 for 8 cogs on the rear then switch to the front and drop down to the 6th and start again. Higher drivetrain efficiency and no bigger gap in the gear ratios eyeballing the chart
I want to play with this on my road bike and deco on my TT bike with only the single button extension shifters!
____________________________________________________________________________
Firefly FF050
Scott Plasma 5 eTap
Trek Fuel EX9
PostPosted: Sun Jun 01, 2014 9:25 pm
Sequential KICKS ASS on the road...
The bike here...
http://www.pezcyclingnews.com/page/tech-n-spec?id=100596
The video of function here...
https://www.youtube.com/watch?v=eq_BgmJ3a-o
This could be done to ANY electronic drive system with very little effort.
It's intuitive and functions flawless.
charles@pezcyclingnews.com
There are no new unread posts for this topic. Sram Etap shifting noise/problems shifting smoothness.
Allen254
Tue Jan 16, 2018 6:57 am
jlok View the latest post
There are no new unread posts for this topic. SRAM shifting with Di2
sturvey
Sat Mar 11, 2017 6:28 am
Racingevo View the latest post
There are no new unread posts for this topic. XG-1190 shifting
beanbiken
9
470
Thu Dec 14, 2017 9:48 am
2old4this View the latest post
There are no new unread posts for this topic. Sram red 22 shifting issue
Olivv
10
952
Tue May 16, 2017 5:44 pm
Olivv View the latest post
There are no new unread posts for this topic. Why Pro teams still using old Dura Ace shifting
bikemaniack
Mon Apr 24, 2017 5:44 pm
wpccrunner View the latest post
Users browsing this forum: 2old4this, aplcr0331, Google [Bot], Google Adsense [Bot], LouisN and 26 guests
