Bontrager seatpost rotary clamp/ears (+SLR carbon rails)
sanrensho
by sanrensho
Does anybody happen to know the weight of the rotary clamp hardware (ears + bolt + rotary clamp) for Bontrager seatposts?
Also, Bontrager lists two optional ears for carbon oval rails: 7x9mm and 7x10mm. Is the 7x9mm a better choice for Selle Italia SLR carbon rails (7x9.6mm)?
Thank you.
FIJIGabe
by FIJIGabe
If I remember correctly from my build, it's 12g.
For your saddle, I'd go 7x10.
sanrensho
by sanrensho
^^^Thanks FIJIGabe. Is that weight for the ears only? Because I think all the loose parts weigh a bit more (ears, bolt, spring, rotary clamps).
FIJIGabe
by FIJIGabe
Sorry, I was really off. The weight of the ears is 29g for the 7x10 versus 21g for the standard 7x7 version.
sanrensho
by sanrensho
Thanks! I wish someone would make a lightweight version of the rotary clamp hardware.
erwizy4p5
by erwizy4p5
I wish someone would too
