It is currently Sat Oct 21, 2017 12:56 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Vittoria Corsa SR
PostPosted: Tue May 27, 2014 7:59 pm
Hi,
I've just bought a couple of these tubular tyres and need to get them stretched, glued and mounted ASAP.
I've tried googling this and some posts seem to suggest that Vittoria have changed the valve system recently but I don't quite understand the answers and none are specifically about my tyre.
They used to come with a red valve which you would unscrew, put in an extender at the base then the red valve on top of that.
These tyres have come with a brass valve which doesn't appear to be removable. Do SRs not have the removable stems, or have Vittoria changed the system? How can I make it longer for my deep section rims?
Thanks
Phil
 Post subject: Re: Vittoria Corsa SR
PostPosted: Tue May 27, 2014 8:04 pm
You would have to use a valve extender that is compatible with that type of valve.....I think SRAM makes some.
http://www.landrys.com/images/library/Z ... 2_12_z.jpg
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Tue May 27, 2014 8:05 pm
Do you know if they've changed the design or if it's specific to the SR?
PostPosted: Tue May 27, 2014 8:35 pm
I've figured it out thanks. First time I've encountered this type of valve
PostPosted: Wed May 28, 2014 7:08 am
It's the same as on Continental now I think, I'm using this type of valve extensions http://www.tufo.com/valve-extensions/ . Otherwise great tubular. I've bought one for the rear, but immediately bought for the front too. Very stable and supple.
PostPosted: Wed May 28, 2014 6:49 pm
Thanks, I'm looking to forward to getting out on them.
I realised I could use my existing vitorria extenders by removing the core so all good.
There are no new unread posts for this topic. Vittoria Corsa G+ TLR ?
lyrictenor1
9
667
Fri Aug 04, 2017 4:23 pm
3Pio View the latest post
There are no new unread posts for this topic. Vittoria Corsa Elite tubular tire
3Pio
14
672
Sat Oct 21, 2017 12:21 pm
There are no new unread posts for this topic. Vittoria Corsa G+ Tubular Review (vs Conti Comp vs Veloflex Arenberg & Carbon)
sethjs
25
5327
Thu Feb 16, 2017 7:58 pm
shimmeD View the latest post
There are no new unread posts for this topic. tubular Corsa G+, 23 vs 25 on Bora 2015
Alexandrumarian
Thu Aug 03, 2017 2:49 pm
Alexandrumarian View the latest post
There are no new unread posts for this topic. Victoria Corsa G+ Puncture Protection
Squashednuts
10
612
Thu Aug 24, 2017 8:43 am
bm0p700f View the latest post
Users browsing this forum: 3Pio, Bing [Bot], Greatestalltime, JayUK, leej88, Miller, sp3000, ToffieBoi and 26 guests
